Cab and Bed Weight
Old Mar 1, 2016 | 09:32 PM
jetrinka's Avatar
jetrinka
Cab and Bed Weight
The truck in question is a 75 F250 single cab long bed.
How heavy is the cab and bed on these trucks? Is a lift truly needed or can 4 strapping men at each corner handle it? Perhaps 3 men on one side and a cherry picker at the other.
The truck doesn't have much rust at all but I am wanting to pull the cab and bed off, rust proof the bottoms of them and coat the frame as well.
Old Mar 1, 2016 | 09:56 PM
twinzilla's Avatar
twinzilla
4 dudes should be able to pick up the bed no problem, and the cab if it's somewhat disassembled (the cabs are pretty heavy with doors, glass, etc.).
Old Mar 1, 2016 | 10:01 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Some were on here is the exact weights thanks to mikeo0o0o0, because he had them off and weighed them. Bed weight of 472 lbs comes to mind?
Yes 4 big guys can man handle it, or 2 with one running the cherry picker and rigged right. Have a solid surface to roll it on though. And be more careful with the cab, great way to get hurt. It can be difficult to rig for a cherry picker, but doable.
Shapie mark the door hinges and leave them on the cab, mark and pull the doors. You can also cherry picker the complete front clip minus the hood.
Old Mar 1, 2016 | 10:06 PM
jetrinka's Avatar
jetrinka
^^Wow thanks for all the pictures! Certainly some great ideas for lifting with a cherry picker going on there.
Old Mar 1, 2016 | 10:16 PM
77&79F250's Avatar
77&79F250
No big deal, you do know they have been right here the whole time with a few more ideas.? No matter how you do it, just rig and lift safe.
1 guy can straight lift one side of the bed, while the other gets some saw horses and pipe under it and then pull the truck out from underneath.
Stand on the bed bolts while the other guy uses the impact to break them loose. If the carriage bolt gets pushed up you can strip the square carriage bolt hole in the bed with a hot rod impact.
https://www.ford-trucks.com/forums/1...then-some.html
Old Mar 1, 2016 | 10:52 PM
hoss73ford's Avatar
hoss73ford
Wow the pics are awesome. Gotta lift a '63 cab off a donor truck this summer and this gives me ideas. I probably will not have help so have to make due with what's possible
Old Mar 1, 2016 | 11:11 PM
HIO Silver's Avatar
HIO Silver
According to Super FTE Guy "Mikeo0o0o0"....
The cab weighs: https://www.ford-trucks.com/forums/1...l#post14254699
.. and a long bed bed weighs: https://www.ford-trucks.com/forums/1...l#post14257591
And there you have it.
Old Mar 2, 2016 | 12:09 AM
privateer, eh's Avatar
privateer, eh
Yeah, cherry pickers are nice, glad I finally got one. Going to use it this week to put the beam onto my gantry crane. Like Rich's pics, there a lot better than mine LOL.
Old Mar 2, 2016 | 07:27 AM
77&79F250's Avatar
77&79F250
Front clip pic, one man hood pull and a big ol flat bed. That cherry picker probably busted a cherry with that one.
Old Mar 2, 2016 | 04:37 PM
privateer, eh
That flat deck probably didn't do that cherry picker any favors I bet. I've bent mine already but it may not have been meant to be used as a cantilever crane, LOL
Old Mar 3, 2016 | 02:16 AM
mike1202002's Avatar
mike1202002
I would of bet money that a cab weighed more than 317 lbs and a bed more than 397.
Old Mar 3, 2016 | 07:39 AM
77&79F250's Avatar
77&79F250
His statement: 317 lbs. This is a completely (and I mean completely) stripped, bare cab.
Bed could be a twin gas flap and might have the filler necks still in it and you can always pull a t/g to lighten it up.
A fully loaded cab, glass, all wiring, doors seat I bet is in the 500 to 600 range? Here is how you haul a cab or bed with another Ford.
Put pieces of cut down 2x4 in the stake pockets to keep it from sliding around.
mikeo0o0o0
34
Jun 8, 2021 01:55 PM
JGraz
Feb 10, 2019 07:31 PM
godblessmud
General Automotive Discussion
21
Jan 26, 2008 09:11 AM
rboeding
Nov 15, 2005 08:34 PM
