Tach Install
Old Oct 26, 2012 | 07:08 PM
roninx17's Avatar
roninx17
Tach Install
I'm in the process of wiring an aftermarket tach onto my 67 f250 and I'm not too sure where to splice the "power" red wire into the truck. The instructions say to splice into the battery fuse, however I do not have one. I was looking at splicing into the ignition switch but I'm not sure which wire is a constant 12V while in the run position. There is a red wire with a thin green stripe that looks promising, but I'm looking for the guessing game. Any other locations or suggestions are greatly appreciated.
Old Oct 26, 2012 | 09:33 PM
critterf1's Avatar
critterf1
Use a test light.
Old Oct 26, 2012 | 10:46 PM
vwfreak's Avatar
vwfreak
There should be "Aux" terminal sspots on your fuse box on the firewall back behind the light switch and ingnition. That's where I plugged mine in.
Old Oct 27, 2012 | 06:26 AM
roninx17's Avatar
roninx17
I'll try the test light. As far as the Aux on the fuse box I don't have one. All locations are for various lights, cigar, and heater. Unless You are talking about the two spade terminals. I figured those are related to the light fuses that are next to them. They aren't labeled. I'll take a look at the wires behindthe spades and see if they look promising.
Old Oct 27, 2012 | 09:14 PM
Joeseph's Avatar
Joeseph
I have a A/c fuse in my fuse box, my trucks a old fleet truck it never had a/c so I just tapped into it.
Old Oct 31, 2012 | 05:26 PM
roninx17's Avatar
roninx17
Connected to the turn signal and brake light fuse. Works.
Old Nov 1, 2012 | 07:58 AM
Freightrain's Avatar
Freightrain
Yup, anything that turns on/off with key will be fine. It won't draw enough power to hurt anything.
I usually try to stay away from fuses like that. Only cause if you have a problem, you loose those lights(while on the road or whatever). I'd pick Radio or heater? Something less of importance. Just saying.
Old Nov 1, 2012 | 07:50 PM
roninx17's Avatar
roninx17
Funny thing is my lights don't work anyway. Only the front passenger turn signal and interior lights. On that topic how do you remove the headlight switch **** and the shaft its connected to. I have the whole assembly loose, but the **** won't come out.
Old Nov 1, 2012 | 08:36 PM
gangstakr's Avatar
gangstakr
On the headlight switch, look for a spring loaded push button. Push it down while removing **** and shaft as one piece. The **** and shaft are one piece so don't try to remove the **** from shaft.
Old Nov 2, 2012 | 06:43 AM
roninx17's Avatar
roninx17
Awesome! I saw the button on top but didn't put 2 and 2 together. I figured the **** and shaft were an assembly just didn't know how to get it out. Going to go do that now. Thanks everybody for the tips!
Old Nov 2, 2012 | 09:17 PM
gangstakr's Avatar
gangstakr
Did you remove the **** and shaft?
newrider3
15
Mar 26, 2010 09:58 AM
86F150302
Jan 9, 2008 10:16 PM
SR77
Electrical Systems/Wiring
Jul 1, 2003 08:26 AM
newtattoobob
1983 - 2012 Ranger & B-Series
Oct 20, 2002 12:05 PM
