DOES ANYONE KNOW WHICH VALVE I SHOULD BE USING TO RECHARGE MY A/C R-134R I SE VALVES ON THE PASSENGER SIDE AND UP FRONT TOP NEAR RADIATOR HOUSING.DEALER SAYS THEY AR NOT ALLOWED TO TELL ME?
Low pressure side on most Ford 6's are passenger side actually on the evaporator/accumulator housing. They have black caps. It is the only fitting that your hose will attach to, hopefully.
Originally posted by jhpaint Low pressure side on most Ford 6's are passenger side actually on the evaporator/accumulator housing. They have black caps. It is the only fitting that your hose will attach to, hopefully.
THANKS A WHOLE LOT,I'M PREPIN FOR THE HEAT .HOW ABOUT THE SPAK PLUG ON A 99 4.0 SOHC PASSENGER SIDE CLOSEST TO THE FIREWALL
Haven't tried to pull that plug out yet. I have the OHV, I would guess you need to remove the plastic cover off the top of the engine, but I have no clue from there.
