IPR GONE BAD!?
Old Oct 28, 2012 | 02:15 AM
Lazy_pig's Avatar
Lazy_pig
something about that ipr duty cycle and the amount of pressure doesnt look correct :P
Old Oct 28, 2012 | 07:10 AM
kupiec20's Avatar
kupiec20
keep the comments coming because these numbers mean nothing to me.
Old Oct 28, 2012 | 05:11 PM
kupiec20's Avatar
kupiec20
the numbers i have is that live data?
Old Oct 28, 2012 | 07:17 PM
oldbird1965's Avatar
oldbird1965
I agree with what Lazy said and the IPR & ICP are considered live data.
I also agree that the % might be right but the ICP is waaaay high.
The rest of the post is fault codes.
Old Oct 28, 2012 | 08:17 PM
rideracelivemx7's Avatar
rideracelivemx7
I jut don't see it possible for thoughs numbers to be correct, the IPR would have to be 100% closed to get that much pressure. At 14% it's only closing that much which I believe is around cranking percentage.
I don't recall you telling me that you left the black trucks IDM in the truck and drove it. Blue smoke and blowing/eating oil/ studdering is a oil pressure issue. I'm still thinking injector orings. Any thing is possible
Old Oct 28, 2012 | 08:31 PM
kupiec20's Avatar
kupiec20
i took the IDM out of the black truck and tried it in the white one and had the same issues. so revving the engine and getting no black smoke out the tail is a bad oring?
Old Oct 28, 2012 | 11:11 PM
fordman67's Avatar
fordman67
To me,for icp to be that high either the icp is giving a bad signal of high pressure and thus driving ipr % down or ipr is stuck or restricted causing high icp.
At least that is my view.a mech icp gauge or icp swap will confirm or deny either situation.
Old Oct 28, 2012 | 11:21 PM
Lazy_pig's Avatar
Lazy_pig
Agreed gotta make sure that icp is reading correct first
Old Oct 29, 2012 | 02:38 PM
rideracelivemx7
Black smoke is irrelevant to your issue, blue
Smoke is saying oil burning or low injection pressure. A mechanical gauge would certainly help rule out an oil issue.
Old Oct 29, 2012 | 05:24 PM
kupiec20's Avatar
kupiec20
where can i get a mechanical gauge? and how do i use ut?
Old Oct 29, 2012 | 06:29 PM
fordman67's Avatar
fordman67
If u look in the tech stickys at the top there should be a parts list.then it gets screwd into the oil gallery in a head.or swap icp to the running truck and monitor icp to see if it pegs high as well...
Old Oct 29, 2012 | 09:33 PM
Lazy_pig's Avatar
Lazy_pig
probably the easiest/cheapest way
Jason Salsbury
6.4L Power Stroke Diesel
Feb 26, 2018 06:10 AM
vegas_alex
18
Dec 13, 2015 08:51 PM
jjlrrw
17
Aug 22, 2015 08:31 AM
diesel-fitter-bum01
19
Jun 5, 2012 06:11 PM
millermad
Dec 10, 2006 04:22 PM
