C-6 output shaft variations
I have a C-6 and motor from my 76 Highboy , so divorced set up with yoke and I would like to use it in my 78 married setup. The output shaft from the 76 C-6 like I said has the yoke and packing nut so the shaft length variation is only the threaded portion of the shaft which the nut goes on. Is it possible to use the C-6 with current shaft in a married application ? Has anyone out there done this ? Thanks in advance for any help!
The entire transmission has to be disassembled to remove the output shaft. There's a gazillion snap rings, washers in a C6, better make sure you re-install them in the correct locations.
The forward/direct/reverse steel and lined clutch plates are all different, as is the number of each. Make sure you reinstall these in the correct locations. And take lots of pics during disassembly, cuz you'll need them.
78blueford
01-10-2003 06:22 PM
71swissaqua
07-14-2002 12:22 PM
