DEF in fuel
Old Oct 26, 2012 | 06:36 PM
  #61
kper05's Avatar
kper05
Another question.
In this scenario where the fuel tank is contaminated and you follow HD’s instructions for unplugging the inertia switch to disable the fuel pumps, do we only need to drop the tank?
If the pumps never run, the lines should be free of contaminants.
That would be only procedure B steps 1-2.
I would add cleaning the filler tube, too.
I guess the safe approach when you’re possibly dealing with an $11,000 repair, clean the lines too with procedures B and C.
Old Oct 27, 2012 | 10:37 AM
  #62
Powerdude's Avatar
Powerdude
Originally Posted by 11red250
Thanks to you all that have replyed. I'm about sick to my gut about this,and cant grasp why such a small amount would cause such a problem. About one pint or less! Im just going to change fuel filters tonight as the warnings are gone and hope for the best. This truck seems way to sensitive to a small but stupid mistake. Should have went with a gasser ????
The reason such a small amount will do this is because urea is one of the most corrosive substances known to man, especially at the concentration it is used as a catalyst for reducing emissions.
Old Oct 27, 2012 | 11:10 AM
  #63
bridge's Avatar
bridge
Sick 'n Tired
That's not quite right. It's actually not corrosive to most anything other than aluminum, and even then only slightly. On it's own its not acidic or basic when dissolved in water. This is because its primarily nitrogen which is extremely stable. If it were corrosive we'd all die of renal failure before birth.
The reason this instance was so bad was because of water corroding and rusting the internals of the HPFP. The only problem urea brings to the equation is it will crystallize on the media of the fuel filters.
Old Oct 27, 2012 | 11:15 AM
  #64
Chad149's Avatar
Chad149
[quote=Painted Horse;12406768]People get in a routine of Open the fuel door and take off the green cap. That is one advantage of GM putting the DEF fill some place other than by the fuel fill.=quote]
Under the hood opens up a whole new list of possable places for DEF to go. My guys at work repair Sprinter vans, and the DEF fill is under the hood. Yes, fuel system repairs are expensive but so is the whole motor. Does not take long when it gets put in the crankcase. Will cause the engine to overheat when put in the coolant tank (eats the brass off the thermostat). So far no brain farts causing it to be dispensed into the brake reservoir........
Old Oct 27, 2012 | 11:26 AM
  #65
budman-mo's Avatar
budman-mo
I have a friend who has both gas and diesel trucks and runs a daily route.
After running the gas one for a week or so while having work done on the diesel he was driving the diesel one for the first time and grabbed the gas nozzle by mistake. He said something was distracting him and while looking at that he grabbed the gas by habit but figured it out after 10-15 gal went in. He just called a wrecker and got it drained.
We all make mistakes, some just because we get tired or distracted.
Old Oct 27, 2012 | 12:10 PM
  #66
Hdslider's Avatar
Hdslider
The best scenario. Would be disable the inertia switch by unhooking wire at switch. Get it towed to the house or a shop and drop tank and. Flush and clean fuel pickup intank. And as KPER05 STATED Clean filler neck. Since def is water /urea it should go staight to bottom of tank. And if you felt not sure pull fuel filter and flush then wait 2 hours to see if any crystals pop up. As long as engine never turns over you should be fine.
Old Oct 27, 2012 | 12:58 PM
  #67
shorebird's Avatar
shorebird
Originally Posted by kper05
I bet the tow truck driver will have to turn the key to on to get it out of park.
I am a Tow Truck Operator that tows for the local Ford dealer.
The truck can be put in neutral without turning the key.
You need to go under the truck and disconnect the shift cable from the shift lever on the side of the transmission.
You can then move the lever by hand two clicks from park to the neutral position.
WARNING! BLOCK THE WHEELS OF THE TRUCK TO ENSURE THAT IT WILL NOT ROLL WHEN THE TRANSMISSION IS MOVED FROM PARK!!!
Old Oct 28, 2012 | 11:26 PM
  #68
mrjc's Avatar
mrjc
Well that is interesting. Good to know. Hope the thieves don't visit the FTE forum and read that, they probably cant read...english
Old Oct 29, 2012 | 04:46 AM
  #69
shorebird's Avatar
shorebird
Who do you think I learned it from?
Repo 101
Old Oct 29, 2012 | 07:10 AM
  #70
kper05's Avatar
kper05
Another reason to set your e-brake.
Unless you can get around that one, too!
Old Oct 29, 2012 | 07:15 AM
  #71
MisterCMK's Avatar
MisterCMK
Pick the truck up backwards. Then the e brake isn't a problem. Or slim Jim the door and release the brake.
Old Oct 29, 2012 | 05:23 PM
  #72
shorebird's Avatar
shorebird
I have a 9,000# winch on my truck.
I carry 3 ****** blocks so I can pull 27,000#
I can (and do when necessary ) winch my truck back under the free rolling front wheels until the edge of the deck is at the rear wheels.
Then I pour a bit of soap on the deck and drag the rear wheels up onto it.
If I have to I can soap the rear wheels all the way up the deck when I pull one from the rear.
One way or another it's going with me.
Old Oct 31, 2012 | 12:25 PM
  #73
nitrogen's Avatar
nitrogen
not corrosive huh. urea is NH3 IIRC. anhydrous ammonia, which is the pure form will give a horrible chemical burn and becomes acidic when combined with water
Old Oct 31, 2012 | 12:33 PM
  #74
bridge's Avatar
bridge
Sick 'n Tired
Nope, urea is not NH3. Its CH4N2O. Carbon and oxygen makes all the difference.
Most of us don't pee anhydrous ammonia. If anyone does let me know. I can think of a few cool party tricks you could do.
wrknstf
Jul 2, 2011 02:02 PM
mariosb11
Jan 15, 2009 02:33 PM
B1GKAHUNA
Dec 30, 2006 09:21 AM
