4wd
Old Oct 18, 2007 | 01:07 AM
jrob_07's Avatar
jrob_07
4wd
I took my truck in to get my transmission replaced and I asked the guys to look at the 4wd to see why it wasnt engaging. Well turns out that it was engaging and getting power to the axel but it wasnt gettin power to the wheels.
Any ideas on what it might be?
Old Oct 18, 2007 | 07:44 AM
wendell borror's Avatar
wendell borror
I would say it was the hubs, what year is your truck?
Old Oct 18, 2007 | 09:17 AM
matthew71's Avatar
matthew71
Ditto on the hubs, especially if it is 98 to early 00 with the oh so problematic vacuum pulse hubs. If it is the VPHs that you have, the problem could also be a vacuum leak or vacuum solenoid. If any of the above is your problem, the easiest fix (and way cheaper than the dealer) is to replace the vacuum hubs with a set of AVM manual hubs. I made the switch recently and they work great. Also see the really long thread on the vacuum pulse hubs.
Old Oct 22, 2007 | 01:03 PM
jrob_07's Avatar
jrob_07
yea its a 99 and i 50 bucks really is proly the max i could spend on it right now cause i'm in college and have no money haha
Old Oct 22, 2007 | 01:18 PM
chuckbrodeur's Avatar
chuckbrodeur
Probably the vacuum going to the hubs. The hubs require a vacuum connection to engage or disengage. If you search here, there are a couple of good threads on the subject. I was able to fix mine by carefully removing the hub lock and cleaning the O-ring. New o-rings cost about $1.50 each at a ford dealer. The trick is to not break the plastic tabs on the hub locks, otherwise, they're trash. Ford recommends using a special tool but I'm able to remove them by wedging small finish nails in each pair of tabs and pulling the hub lock off.
The AVM manual hub locks are about $100 for the pair. I have a pair of those now ready to install if/when the vacuum goes again.
http://www.tellico4x4.com/product_in...5eac1059c1cc72
dispatch55126
1997 - 2003 F150
Jan 5, 2014 07:09 PM
Joejoecat
Jun 22, 2011 07:52 PM
yachtonwheels
Offroad & 4x4
Dec 23, 2010 10:59 AM
Jordan Septo
Dec 12, 2007 09:23 PM
is300wrx
2004 - 2008 F150
37
Dec 7, 2006 05:38 PM
