94 f150 codes ?
Warm the engine. Then ground the STI wire (Activate Self-Test) and start the engine and and you are in the KOER self-test. Follow the points below and count the codes.
Engine Running Self-Test
Special Notes:
On vehicles equipped with the Brake On/Off (BOO) circuit, the brake pedal MUST be depressed and released AFTER the ID code.
On vehicles equipped with the Power Steering Pressure (PSP) switch, within 1 to 2 seconds after the ID code, the steering wheel must be turned at least one-half turn and released.
On vehicles equipped with E4OD transmission, the Transmission Control Switch (TCS) must be cycled after the ID code.
The Dynamic Response code is a single pulse (or a 10 code on the STAR Tester) that occurs 6-20 seconds after the engine running identification code. (See Code Output Format in this section.)
When/if the Dynamic Response code occurs, perform a brief wide open throttle.
How To Run Engine Running Self-Test
DO Deactivate Self-Test.
Start and run engine at 2,000 rpm for two minutes. This action warms up the HO2S.
Turn engine off, wait 10 seconds.
Activate Self-Test.
Start engine.
After the ID code, depress and release the brake pedal if appropriate. See Special Note on previous page.
After the ID code, within 1 to 2 seconds, turn the steering wheel at least one-half turn and then release it, if appropriate. See Special Notes above.
If a Dynamic Response Code occurs, perform a brief wide-open throttle (WOT).
Record all Diagnostic Trouble Codes (DTCs) displayed.
DON'T
Depress the throttle unless a Dynamic Response code is displayed.
You can post the Calibration number here and we can look up the right number for you.
The PCM Computer is located in the drivers kick panel but you take it out from under the hood.
PCM Computer location:
PCM Computer plug with 10mm bolt:
The F???? number is F5TF-12A650-ALA in the photo on the PCM Computer plug below:
Calibration number "4-54E-R10" in photo below:
