Modular V10 (6.8l)
EGR Valve
Old Oct 21, 2012 | 12:13 PM
ryno_rx8's Avatar
ryno_rx8
EGR Valve
Hey guys, got a '99 F250 v10 with about 158k on it. I was wondeting what issues I might have if I remove my egr valve and block it off? I have an SCT that allows me to turn it off. Would I benefit from this or not? Hurt anything? Thanks.
Old Oct 21, 2012 | 03:26 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Well more then likely the V10 won't run right if you have the EGR Valve cut off. Probably no benifit taking it off or keeping it on. You would for sure have your check engine light on all the time which may be distrubing I know my mom says it is disturbing on her 97 Expy since we need to fix the EGR Valve. Also you might see worse gas mileage I know our 97 Expy is seeing a slight lower gas mileage.
Trav
Old Oct 21, 2012 | 05:13 PM
ryno_rx8's Avatar
ryno_rx8
Awesome thanks. I was considering a set of headers for non EGR is why I was curious
Old Oct 23, 2012 | 08:05 PM
mikeismadness's Avatar
mikeismadness
You can run no EGR. You may get slightly worse MPG, and throw a CEL if you can't turn it off but sounds like you can. It will more then likely still pass emissions. But I'm not 200% sure on that.
cdelsol83
Jul 5, 2010 08:36 AM
viperrtblck
6.4L Power Stroke Diesel
Mar 13, 2010 06:59 AM
pman10
Modular V10 (6.8l)
Dec 13, 2009 05:24 PM
rokhedjo
Modular V10 (6.8l)
Jul 23, 2008 03:51 PM
