Part identification needed.
Old Oct 20, 2012 | 09:11 PM
bergy 2000's Avatar
bergy 2000
V10 engine, looking at the engine from the outside. What is the metal canister to the right of the air filter? What does it do? Where do the lines go and what do they do? They go from metal to rubber to metal to rubber to metal and run along the frame rail. They are marked gas/fuel, but do not go through the fuel filter. Is this part of the emissions? Charcol canister? While crawling under the ex tonight just checking things out, I noticed there are rubber hoses that lead to this canister close to the fuel filter that are getting old and soft. They are 3 short hoses in that area with a T or Y connecting up to some metal lines. They look very easy to replace but I just want to be prepared if they are full of fuel or something. I hope it's just some vacuumed hose for the tank or something.
Thanks for the help.
Old Oct 21, 2012 | 02:41 AM
Monsta's Avatar
Monsta
Sit. Stay.
You guessed it! Charcoal canister for evaporative emissions.
Old Oct 21, 2012 | 07:13 AM
bergy 2000's Avatar
bergy 2000
So what do the lines have in them?
Old Oct 21, 2012 | 08:01 AM
bergy 2000's Avatar
bergy 2000
If I want to replace these hoses what should I know? Will I need to purge anything after the change? I am assuming there should only be vapor in the lines. Does anyone know the exact size of these hoses?
Old Oct 21, 2012 | 12:09 PM
bergy 2000's Avatar
bergy 2000
It appears the hose is marked 12.7 mm which converts to 1/2". Will any 1/2 fuel hose suffice?
Old Oct 21, 2012 | 01:12 PM
Monsta's Avatar
Monsta
Sit. Stay.
They are more than likely "full of" fumes. As the fuel in the tank evaporates it is caught by this system, stored and then burnt in the engine based on cycles determined by the PCM.
Personally I wouldn't spend the money to change them unless they throw a code. Even disconnected , it won't affect driveability.
Old Oct 21, 2012 | 02:48 PM
bergy 2000's Avatar
bergy 2000
I was thinking the same thing but do like to be proactive rather than reactive. I guess since I know about them and their condition if something does happen, I know where to look first. On the other hand the cost wouldn't b much to replace them to ease my mind. Decisions, decisions...
Old Oct 21, 2012 | 05:47 PM
Monsta's Avatar
Monsta
Sit. Stay.
If you do, then simple fuel hose will suffice. As to the size...might be a trial and error thing but it sounds like you're on the right track.
Lucasbradley89
Jan 25, 2019 01:06 PM
F250Projrect
Jul 12, 2013 06:14 PM
bang4dabuck
16
Jul 23, 2008 03:58 AM
jdmorg
General Automotive Discussion
13
Oct 10, 2005 01:26 PM
ham4ever
Nov 7, 2004 08:19 AM
