I need idle help
Old Oct 20, 2012 | 04:07 PM
5speed50's Avatar
5speed50
I need idle help
I have a 96 explorer with the push rod v-6 and the idle is acting up, sometimes it will rev to high ,some times it will float and sometimes i have to hold the gas to the floor to start, then it might be ok for a short time, anyone have some ideas, I look at the pcv valve and vaccume lines and tried a new iac, and idle sensore, and cleaned the mass air
thanks
Old Oct 20, 2012 | 07:13 PM
aquanaut20's Avatar
aquanaut20
Check the fuel delivery system, incl leaking injectors... Philip
Old Oct 21, 2012 | 05:42 AM
5speed50's Avatar
5speed50
thanks, how do i check the injectors
Old Oct 21, 2012 | 10:56 AM
aquanaut20's Avatar
aquanaut20
During the pressure test, bring the system up to spec and then check for leak down when ignition is shut off....... If you see leak down check FPR first then pull the injectors for testing/cleaning... Philip
cullenkyla
2009 - 2014 F150
Nov 18, 2014 05:26 PM
nighthawk285
Mar 4, 2007 11:07 PM
waro
Jul 30, 2006 06:23 PM
SSCX2
Aerostar
Jun 16, 2005 02:00 PM
buckford
Jan 22, 2004 08:41 AM
