I have read about cutting the rivits off of the front bracket and flipping it to get a 4-5 inch lower rear end. In my case i dont want that much. More like 2 inches. My thought here is to cut the rivits, redrill 4 holes 1.5-2 inches lower on the bracket, move the bracket up and not flip it at all. Obviously I would replace the rivits with grade 8 bolts.
Thoughts?
It'll work. However, I do recommend welding reinforcement plates and even adding some gussets to address the shear forces in a smaller area. In essence, make the outboard facing areas thicker and stronger.
Thoughts?
I'm wondering how this is working out for you?
from what I have been reading the resulting drop will be closer to 1/2 the amount you move the front pearch.
So by flipping the pearch and moving the spring 4-5 inches you would net approx 2.5" drop.
Your idea of moving the spring 1.5 or 2 inches would result in 1" drop....
