Sponsored by: Real Truck
Tire wear
Old Oct 18, 2012 | 11:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Tire wear
Do front or rear tires traditionally wear faster?
Old Oct 19, 2012 | 12:50 AM
joe_r_dog's Avatar
joe_r_dog
depends on how often you rotate then, the loads you pull and tire pressure. if you dont tow anything or haul things in the bed, then yes, the fronts will wear fast because there is more weight up front with the motor and tranny. they should be rotated enough so that they all wear even because tires will generally start to get choppy if they are kept up front too long. people say 5k for 4x4s but i think 10k would be fine also. the rears will wear more if you have a programmer generally.. LOL
Old Oct 19, 2012 | 12:56 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Makes sense, but I disagree with the rotating part. That doesn't prevent the wearing, it circumvents it. I ask because 2 tires are more worn than the others and I want to even it out by rotating the tires appropriately.
Old Oct 19, 2012 | 01:21 AM
joe_r_dog's Avatar
joe_r_dog
Well yes. Whatever circumvents means. My neighbor pulls trailers quite a bit so his rears wear more. My shop teacher has some new bfn rugged terrains and they are getting choppy. The drives on my dads log truck get choppy if they aren't rotated enough
Old Oct 19, 2012 | 04:39 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I wear out rears faster...alot faster.
with a PSD up front and limited towing...and light foot...the fronts will wear quicker. All that weight getting scrubbed each time you turn does a number on tires
as with everything, it's all about application. if you tow a ton, the rears are going to eat up quicker.
Old Oct 19, 2012 | 04:58 AM
kd0axs's Avatar
kd0axs
Looks to me like the rears wear out faster
https://www.youtube.com/watch?v=RrXL...e_gdata_player
Old Oct 19, 2012 | 05:40 AM
2000silverbullet's Avatar
2000silverbullet
Rears on my stock Mich's were wearing faster. The fronts were wearing differently (cupping) but the rears were easily discernable from the fronts. I don't spin the tires alot (nor can I really since the traction control is always on) but you could hear the tires almost shredding on the asphalt at every take off.
Old Oct 19, 2012 | 07:27 AM
BigPigDaddy's Avatar
BigPigDaddy
Originally Posted by joe_r_dog
... the rears will wear more if you have a programmer generally.. LOL
Agreed.
My rears were wearing more because I am due for rear diff fluid service, so I can hear the limited slip not "slipping" when going around corners. It is even more pronounced on gravel roads.
Old Oct 19, 2012 | 11:35 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Under normal driving, the fronts wear more than the rear. The constant turning and braking is hard on the compound. Also, the front wheels have a caster and camber setting that scrubs rubber off the casing faster than the rear. I rotate at every oil change (about 7k-8k miles).
Old Oct 19, 2012 | 01:03 PM
On Holiday's Avatar
On Holiday
Towing a ton is not that much, I rotate my tires every 5k miles as it is very easy to know when it is time to rotate.
Old Oct 19, 2012 | 11:44 PM
dkf's Avatar
dkf
My rear tires spin faster because they get spun more than the fronts.(lack of traction) The right rear usually wears the fastest. The rears usually wear the center of the tire more than the outer lugs. Putting the rears on the front evens them out. Putting the fronts on the rears takes care of any "feathering" on the tread from turning. I always put the front tire with the most tread on the right rear when rotating.
doubledip
Mar 7, 2019 05:01 PM
donsor
1983 - 2012 Ranger & B-Series
13
May 27, 2014 04:25 PM
pin8246
24
Oct 7, 2012 11:23 AM
turbogus
52
Jan 30, 2012 07:41 AM
wickymustang
Sep 21, 2005 04:56 PM
