Water Pump bolt list
Old Oct 18, 2012 | 05:06 PM
ransom147's Avatar
ransom147
Hi, i've searched and tried, but I can't seem to find a list of the correct bolts with dimensions for a water pump R&R.
I bought a '76 F150 off a guy who said it had trouble with the cooling system. I get the thing home and it's got an aluminum pump on it. looks wrong and correct hole placement. I cleaned the timing cover and read the casting number. Looks like the cover is off a '79 Truck 302. So, the bolts are in cruddy shape, and if someone installed the wrong pump--they could well have used incorrect hardware.
I got an iron pump and a stud kit from O'relly--but they did not have the rest of the bolts as a kit.
I plan on picking up the bolts at Lowes, but I was hoping to verify lengths required. Everything I pulled off looks like 5/16 diam...
The new pump I bought has 8 holes that pass all the way though to the timing/engine cover.
So, if anyone could point me to a resource for this info, I would highly appreciate it!
I will be using an alternator bracket and PS pump bracket on this water pump as well.
Thanks in advance,
Joe
Old Oct 18, 2012 | 05:17 PM
HIO Silver's Avatar
HIO Silver
AMK products sells correct hardware kits. That's dang good way of making sure you have the correct fasteners. The kit number for an SBF water pump is F-306.
Ford Fastener Kits
Old Oct 19, 2012 | 11:09 AM
ransom147's Avatar
ransom147
Thanks for the info, HIO.
I wish I had ordered that 3 days ago! Now, I'm wanting to get this done today, so I'll try to assemble the correct bolts from the store...
kkrapp
May 1, 2013 09:07 AM
universalwrench
Jan 8, 2013 09:46 AM
charleswood6969
Aug 15, 2011 02:31 PM
jommer
Feb 27, 2004 04:02 PM
tadslc
Oct 27, 2003 02:27 PM
