Leak at TStat housing
Old Oct 20, 2012 | 06:51 AM
Supercab's Avatar
Supercab
Guys, I got a nasty 24 hour bug, so I was in bed all day yesterday and didn't work on the truck OR go camping!
I'll be headed out in a bit this morning to put the upper hose back on--thinking about also removing the broken petcock and replacing before pouring the coolant back in.
Like I said before I bought the billet housing and installed on my original pump, NO leaks, then installed it on the AIRTEX pump, NO leaks, then on the current Cardone (new) pump and it kept leaking.....so thats why I went to the RTV
I think it would be easy to make a nice composition gasket for these that would make everything that much easier rather you used a stock OR the billet housing--until THIS 7.3 ALL my Fords have had a composition gasket for the TStat housing-I never used RTV in that area of any of those and never had a leak.
Old Oct 20, 2012 | 07:49 AM
esolcz's Avatar
esolcz
I too had a t'stat housing leak after doing a flush w/ stat out. replaced o-ring, cleaned everything, had annoying drip. bought a fel-pro oring from adv auto. The AA one was 0.125" thick. The one i was replacing (which was new from another shop) was 0.110" thick all around. Still had the one from before the flush - that too was 0.125" thick. I reassembled with the new thick oring, and a bead of permatex around the sealing surface. Now we're good to go - no more weeping drip after a couple weeks.
Old Oct 20, 2012 | 10:33 AM
Supercab's Avatar
Supercab
Wink
I wonder if somehow the smaller O ring you got was the one that goes in the connection to the lower pipe? I know that one IS smaller, but lots of guys, when they get a leak there use the bigger one thats made for the tstat.
Old Oct 20, 2012 | 11:22 AM
Fat Diesel's Avatar
Fat Diesel
Which ever route you choose to seal it, the surface prep remains the same. Use Scotch-Brite to prepare the surface. Use it to dress the o-ring surfaces in a rotational direction. You don't want to see any "radial" lines which go from inside to outside the sealing "lay pattern." All your lines you create with the Scotch-Brite should be running in a large circular pattern. You're typically looking for a #16 finish. With proper surface prep the oring itself should seal without RTV. I have no RTV on mine and it's been on there several years without leaking.
Old Oct 20, 2012 | 08:43 PM
Supercab's Avatar
Supercab
Guys, I WAS able to get the broken off drain plug (I call it a petcock)(I'm from the old school, I guess) out by using an allen wrench (hex) in the middle-the FACTORY drain plugs have a female hex in the middle for this.....but the aftermarket plug from Dorman/Motormite DOES NOT-it also uses a thumb screw rather than a 3/4" male hex like the factory one does.....I actually like the Dorman one better, it was under $5 at Advance.
jchosler
15
Jul 5, 2014 09:42 PM
dave22r
Feb 15, 2013 11:38 PM
Jake_f16
Sep 7, 2012 08:14 PM
DND58
Nov 23, 2009 08:01 PM
JMACC
Oct 10, 2005 09:43 PM
