billet t-stat housing
Old Nov 22, 2009 | 11:30 PM
DND58's Avatar
DND58
I spotted a small trail of anit-freeze running down the lower radiator hose today. The lower hose flange on the water pump is wet, just on the side of the flange. I do not believe it is the lower hose connection or the pump itself. Looking at that same flange from the top, it is dry. The connection between the billet housing and pump is damp, but can't see any fluid, so I'll keep checking.
I installed this housing when I flushed back in June and no leaks till now. All I used then was some faucet lube on the stat o-ring, and tightened housing bolts evenly. If I removed the billet housing to reseal, would you recommend I use some sort of RTV or sealer at the housing flange? If so, what flavor? Is there an o-ring at the lower flange on the pump?
Thanks
Old Nov 23, 2009 | 06:25 AM
Visseroth's Avatar
Visseroth
good question. I need to change mine too at some point as it likes to leak a little though strangely enough has recently stopped leaking. just drips really but drips means a failing seal, sooooo...............
Subscribing.
Old Nov 23, 2009 | 07:07 AM
riverrat41's Avatar
riverrat41
I like the orange RTV.High heat....I use it on all types of applications in the industrial field.
Old Nov 23, 2009 | 02:14 PM
Visseroth's Avatar
Visseroth
so are you recommending RTV on these things? Does the bullet housing have a seal or do you just use the RTV?
Old Nov 23, 2009 | 03:07 PM
riverrat41's Avatar
riverrat41
It does come with a square o-ring just like the factory housing but I feel better about putting a little red/orange high heat RTV on it as well.
Old Nov 23, 2009 | 04:15 PM
big poppa's Avatar
big poppa
I agree with Barry, a bead of that hi-temp silicon will seal it from what alot of people here say. I noticed a leak a couple weeks ago and removed the stat and housing and cleaned up the mating surfaces and reinstalled, no RTV used but all is dry. I had an extra new rubber t-stat seal DS sent me with my housing kit.
Old Nov 23, 2009 | 07:20 PM
SkySkiJason's Avatar
SkySkiJason
Bob Riley advised me to use 'a little' RTV when I had a small leak after installing billet housing on one of my trucks. The billet housing is not 'forgiving' to any imperfections on the other side... That was a loooong time ago and I haven't thought about it since!
Old Nov 23, 2009 | 07:31 PM
Visseroth's Avatar
Visseroth
What about just using RTV? I ordered a bullet housing and I don't think it came with a seal.
Old Nov 23, 2009 | 07:44 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
when i did mine i used some waterpump/thermostat rtv. you can get it from autozone or wherever and its gray. i chose that particular stuff since it would be coolant resistant......
Old Nov 23, 2009 | 08:01 PM
Visseroth's Avatar
Visseroth
ahhh, good point!!!
GoCamping
Nov 12, 2023 06:56 PM
SgtRauksauff
Nov 30, 2015 02:56 PM
Bananarama
Jun 24, 2015 09:56 PM
timmyboy76
20
May 12, 2011 12:12 PM
jimkari
Jul 18, 2008 10:07 AM
