Alternator Issue?
Old Oct 19, 2012 | 07:44 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
The pcm delays alternator output if the temprature is below 60 degvrees, at least
With my 05 excursion. I'm on my 3rd alternator @ 100k, so invest in the best one you
Can afford, if you plan on keepingthe truck.
Old Oct 19, 2012 | 08:45 AM
florida_1959's Avatar
florida_1959
ok I will be pulling the alternator tonight and having it checked. But couple of questions. Is it possible for the glow plug control to be active even if the engine is at full operating temp? Would the glow plug light have to be illuminated? Reason I ask is that yesterday I parked went into the store and when I came out the voltage acted like the glow plugs were on. Output was about 11.9 at start and then slowly came back up to 13.6 even though the engine temp was 192 when I started. It seemed to be more steady yesterday, hovering aroung 13.6 the whole time coming home, but then this am it was back to 11.8 and came back to 13.2-14.1 and fluctuating. How can I check the glow plug control?
Old Oct 19, 2012 | 08:58 AM
Rusty Axlerod's Avatar
Rusty Axlerod
When I bought my truck it had a shiny new autozone alternator on it. After swapping it Again, I took the O'Rileys rebuild to a local shop. Their first repair lasted a week or so and I took the whole truck in to them. They acted surprised (almost offended) their repaired unit failed and spent a lot of time checking the truck and found nothing. Alt was on the bench and running loaded for more than 10min before it started breaking up. They pulled it apart and replaced the regulator/diodes with a different style they referred to as "high amp" for no charge. A couple weeks later it was a slow start and the passenger side battery failed load test so new batteries and no further issues.
I forget the details of the regulator/diode they installed but I was looking over his shoulder at the computer screen and there were several different parts with different specs shown for that alternator. They aren't all the same.
Old Oct 19, 2012 | 10:03 AM
Fulthrotl's Avatar
Fulthrotl
Originally Posted by florida_1959
Ok have an electrical problem. Vehicle is a 2006 with 124K, all stock except for 4" turbo back exhaust.
This past week my batteries went dead, first time in 3 years owning. The batteries are less than 6 months old. I recharged them individually and both pass a full load test. They are currently fully charged yet my scan gauge is goign crazy on voltage. At start the voltage drops to 11.7 then as it comes up it fluctuates excessively between 13.2 and 14.1. Should I have such charging voltage on fully charged batteries? Also I noticed that one of my pod gauges is fluctuating like it is getting some crazy voltage depending on engine RPM. I have no battery or charge light and no codes or CEL. Can the alternator be going? Just hate to replace parts instead of figuring the problem. Alternator is factory ford and as best I can tell the original one.
Thanks
you have bad diode(s). you are getting an AC component in with
your DC output off the bridge in the alternator. you also have one
leaking to ground i'm guessing, which is what is killing your batteries.
if they do an epic fail and do a hard short to ground instead of open,
you have fusible links in your loom to prevent a car fire.
i'm gonna suggest something that gets echoed here a lot:
DC Power alternators are a much better solution than OEM
OEM doesn't provide enough output voltage to properly charge
your batteries.
Old Oct 31, 2012 | 09:36 PM
FordBlueHeart's Avatar
FordBlueHeart
Today I was looking at DC's website and they showed two OEM High output alternators and 2 XP High Output alternators. Plus 3 SPX alternators. Why does everyone suggest the $500 alternator versus the $270 185 amp or the $340 190 amp alternator?
Old Oct 31, 2012 | 10:27 PM
Piolet's Avatar
Piolet
Because it's your money not theirs.
Old Oct 31, 2012 | 11:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
This forum loves the DC alternator.
Just the same one car audo forum loves Tenney alternators, when another worships EA alternators.
Some have no issue with DB Electric alternators and others despise them.
Some like me retrofit large case 3G alternators and keep things all Ford.
There are many good choices out there, some only cost a few bucks and others are extremely overpriced.
Josh
Old Nov 1, 2012 | 02:17 AM
Fulthrotl's Avatar
Fulthrotl
square drawn armature wire, in a hairpin winding instead of
a full wave winding. it's harder to make, and costs more.
i also has less hysterisis loss and eddy currents, cause the
winding has less air in between the coils of wire. it' denser packed.
sorry. you asked....
and if you ask DC power, they will tell you their XP is a better unit
than any of their other units.
the ONLY difference between the XP and all their other units is the
wire type... and the blingy CNC machined front cover....
Old Nov 1, 2012 | 07:22 AM
FordBlueHeart
So is the 190 amp $339 OEM style sufficient for a snowplow or air compressor being added on down the road?
Old Nov 1, 2012 | 09:21 PM
FordBlueHeart
Or should I really save up for the $540 one? Would it be okay to replace the batteries before replacing the alternator? I'm getting 13.2-13.6v according to the Torque app.
Old Nov 1, 2012 | 09:31 PM
Bullitt390's Avatar
Bullitt390
That's roughly 13.4-13.6 on the low end and 13.8-14.0 volts on the high end at the battery.
Not too bad really. Is that where it is all of the time? If so you don't "truly" need an alternator right now, unless you have $600 burning a hole in your pocket.
Josh
Old Nov 1, 2012 | 09:35 PM
FordBlueHeart
KOEO battery voltage is at 11.2-11.0v. After glow plugs shut off it rises back up to the aforementioned voltage.
Old Nov 1, 2012 | 09:52 PM
  #28
Bullitt390's Avatar
Bullitt390
Key On-Engine Off is only showing 11 volts? That's no bueno.
11 volts after start is normal, but not when the engine is off. I would expect around 12.2 volts at the OBD port KOEO
Josh
Old Nov 1, 2012 | 10:17 PM
  #29
BLADE35's Avatar
BLADE35
The Glow Plugs are on at this time at KOEO thats 80-100 amps right there plus everything else Fuel Pump & FICM ect.............
Guess Im going opposite Josh and going with this is Normal
My Batterys are 3 week old and they drop this area 11.6v at KOEO will have to watch it tommoro close
if your gauge updates fast enough you will see it takes another PLUNG in Volts when starter is engauged
Old Nov 1, 2012 | 10:26 PM
  #30
Bullitt390's Avatar
Bullitt390
Ya got me... I wasn't considering the glowplugs KOEO.
Everything sounds normal to me. Volts key-off would tell condition of batteries as well. But it seems to me the batteries and alternator (for a 6G) are reasonably healthy to me.
Josh
