Lift / spring question
Old Oct 18, 2012 | 07:55 AM
Mattb60's Avatar
Mattb60
05 6.0
I recently did a rough country 5' lift. Have enjoyed the lift thus far with regards to ride quality, handling etc.
I am a little nose up (which I prefer to nose down). Can't remember exact measurements but it's about 2-3 inches. The shop that did it offered to block it up some more in the back if the front didn't settle.
Was wondering what would happen if I did b codes in the rear and left the blocks ? How much do you gain with these with no hangers ?
Probably a stupid question, but was just wondering.
Old Oct 18, 2012 | 11:46 PM
VQT's Avatar
VQT
Can't help much on your question since I am new at this also. Someone will come along to answer your question soon.
Can you explain a little more about "rough county 5' lift". Is it a 5" lift? If it is, what was done to the front springs and rear springs? Why are you asking about the B code in the rear now, shouldn't it already raised at least 5" already?
Old Oct 19, 2012 | 10:10 AM
Mattb60's Avatar
Mattb60
The RC (Heckthorn) puts new leafs up front, anti-wrap blocks in the back and new shocks all around.
I think with CTs set up you get a little lift in the back from the new leafs and I'm wondering if on my 155k truck that would help ride quality and give me just a little height to level it out or get closer to level.
Old Oct 19, 2012 | 10:20 AM
EXv10's Avatar
EXv10
Originally Posted by Mattb60
05 6.0
A 5 foot lift? I doubt if the front will settle also. Not a stupid question.
Old Oct 19, 2012 | 10:35 AM
Dave O'Brien's Avatar
Dave O'Brien
Originally Posted by EXv10
A 5 foot lift?
Common sense says that should have been Inches (") Instead of feet (')
I understand why so many people find you a PITA "EXv10" you should let typos go and give some actual insight onto the issue instead of giving the OP a hard time.
Old Oct 19, 2012 | 11:35 AM
Stewart_H's Avatar
Stewart_H
Easy Dave, in Brent's defense, he was being humorous. He just needs to put a smiley there so people know that.
He then went on to advise he doubts the front will settle enough, then closed with telling the OP his question wasn't stupid, as the OP had stated.
Stewart
Old Oct 19, 2012 | 12:15 PM
EXv10's Avatar
EXv10
I was only kidding, I do typos too. And I did give insight to it; many people wait around with fingers crossed hoping the springs will settle but they never do. After you go for a short drive and hit a few bumps it is done.
Old Oct 19, 2012 | 12:26 PM
Misky6.0's Avatar
Misky6.0
nose up, always looks to me like there must be something HEAVY in the back.
Then when you do load up/tow something it gets even worse.
I've always preferred the rear higher (unloaded) so it would end up flat
when loaded.
But, as long as you LIKE it that way - that is what really matters.
Old Oct 19, 2012 | 05:04 PM
EXv10's Avatar
EXv10
when loaded.
I think everyone is used to seeing the front being lower because most vehicles are like that from the factory.
Old Oct 22, 2012 | 09:28 PM
Mattb60's Avatar
Mattb60
It looks like based on an old resurrected thread that F codes might gain me an inch or more in the back.
What would be better/worse about this than just blocking it up more ?
egreco79
Feb 19, 2014 03:00 PM
Darkstahr
Feb 22, 2008 06:49 PM
Homelessduck
Sep 12, 2006 08:52 PM
muffdr
Jan 11, 2005 08:53 AM
