How much does a stock FE weigh? A pal has a hoist and stand I can use but have read a couple stories here about stands breaking and motors falling. I do not want to experience that mess first hand but don't want to have to buy a huge diesel stand either.
Also make sure to get grade 8 bolts to hold that engine to the stand.I had a steel headed 460 on a 1200 lb four leg stand for over a year.I would keep away from those cheap offshore stands that might only hold a SBF shortblock.But I agree that quality is important.
about how much more would a 428 weigh over a 390???
no wonder my swb is squirly when slick,alot of weight on the front tires
need aluminium blocks w/out the massive bore them shiny aluminium 427's have!
I ended up using that one I linked to earlier. I DID use grade 8 bolts. Wouldn't have considered anything less stout. The stand barely moves. I had a friend drill a couple holes in two of the arms effectively shortening them about an inch so I could mount up using the top four holes and keep the center of gravity at a reasonable spot. Motor is now down to the short block and is a bit bottom heavy, but not too heavy to invert by myself and the pin holds it nicely so I can have access to the underside.
