Engine shaking?
Old Oct 17, 2012 | 01:42 PM
FlaresideF150's Avatar
FlaresideF150
Engine shaking?
I had to replace all of my motor mounts on my 95 f150. It has a straight 6. When the passangers side one broke, the engine kind of shook and it had a knocking sound, obviously from the broken mount. I put new ones on and they were good for a while but now its started the shaking sound again when I accelerate in first second and third as well as when i start it up. I know none of them are broken, but when the one was broken, it would shake on start up, while accelerating through first second and third and also at 40 mph. Does anyone have any ideas why this is happening?
Old Oct 17, 2012 | 07:56 PM
stewart89's Avatar
stewart89
Is it for sure an engine shake? If your not positive it could be a drive-line issue. Another possibility could be your having a miss and it's making your engine shake. I just went through this and did a full tune-up and it helped a lot with the shaking aspect. I still have a ways to go as far as getting it to run great instead but I'm on my way haha.
Old Oct 22, 2012 | 07:30 PM
FlaresideF150
Im almost positive its the engine shaking because its the same noise as the broken mount and it stops for a short period of time if i losen the engine from the mount and raise it up then set it back down and tighten everything as hard as I can..
Old Oct 22, 2012 | 08:49 PM
stewart89's Avatar
stewart89
Check your timing and look at your plugs. It's sounds to me like you've got actual engine shake. Your probobly out of snyc and it's giving you "the shake".
hvphotog
1978 - 1996 Big Bronco
Oct 1, 2010 10:55 AM
fishforlife2007
Jul 15, 2010 08:23 PM
speedkingf100
Jul 21, 2003 09:13 PM
