9inch gear set
Old Oct 17, 2012 | 11:02 AM
mcmavv's Avatar
mcmavv
9inch gear set
picked up some ford stuff at an estate sale recently.one of the items is a rear end gear set.what numbers off of it can i post here that will help me determine if A..its a traclock and B..IF its even a 9in.dont have enough posts to put pics up.
Old Oct 17, 2012 | 05:25 PM
hasteranger's Avatar
hasteranger
measure the ring gear, if its 9" then its a 9". For the rest, you could instantly tell if it was a trac lock because it will have the track lock carrier instead of an open carrier with spider gears, so that ones easy. As for the gear ratio just count the teeth on the ring and the pinion.
okie72
Feb 2, 2014 09:46 AM
David LaPell
Sep 21, 2010 06:22 AM
79f100six
Apr 16, 2008 09:10 PM
HUCKSTER-USA
Nov 18, 2006 08:02 AM
BeSee
Mar 24, 2004 09:51 AM
