Murphey's cleaning oil. Been around for years! Works like a champ and leaves a great after scent
Agree 100%. Use this stuff to clean up old saddles. Works like a charm. That deodorizing stuff is also amazing and extremely potent. My trucks PO was a smoker as well and a couple of shots of the deodorizing spray (new car smell) and taking this little upholstery scrubber i picked up at a yard sale to the carpets and light scrubbing to the head liner and youd never know minus the 3-4 burns throughout the interior.....
This is as we got it, never took any inside. You can see the rims with the brake dust.
OK...here are some pics after the cleaning. The PO had the drivers seat recovered 2 weeks before we did the trade so now I will have the passenger seat done to match. $400 per seat with Ford matching material. Just no embossed Lariat in the seats now.
And a couple showing the headlight change and the grill. Started to clean the gray grill for repaint and ended up with this look instead.
Oh... and don't trust the overhead. We all call that the "liedometer". Hand-calculate your economy and if the liedometer is generous by 3-4 MPG, you may need to do some work on your fuel system.
It's a well-known fact that most of our trucks with the overhead MPG readout is way off. There are a very few individuals I've talked with who just happen to have their overhead readout matching their hand calculations, but they are rare exceptions. For the rest of us, the readout is, like Tugly said, anywhere from 2-4 MPG higher than actual.
Don't want to be condescending here, so I'll assume that you already know how to hand-calculate your fuel economy. If not, shoot me a PM and I'll explain how I track my own mileage from tank to tank.
As for the kinds of things which can affect your actual mileage, the more common are:
- boost leaks (silicone boots, up-pipe connections, turbo flange clamps, etc.)
- bad EBPV sensor
- plugged EBPV line to the EBPV sensor
- malfunctioning (mis-adjusted) wastegate
- etc.
Actually the engine was nothing bad at all. I think his mechanic maybe cleaned it.
Tugly.....
So far, the overhead is about .5 mpg off on 3/4+ tank refuel so I think it is close enough to use as a guide as to how the truck is running.
fordtruck661...
Thanks...That is the stock grill. When I started looking at it to repaint, I realized that is is chromed under the factory gray paint. A towel and some laquer thinner cleaned the factory paint and left shiny chrome. I did the area back to the small ridge, all the way around the grill plus around the Ford emblem (which was replaced with a nice one I had laying around) plus the side grills.
Texas Chain Ring.....Sorry about the pictures.....or should I feel sorry about your truck...lol
That's great news! You've got a keeper there. To expand on what I was referring to: Air in fuel will wack the accuracy... and the Superduty Powerstroke 7.3L has many causes of this problem. If you see your overhead go sideaways on accuracy in the future, ask about the solutions to air in fuel (not expensive). In the meantime, enjoy!
looks good. makes we want to clean old green.... maybe.
might just be the angle of the photo, but the color of the airbag on the steering wheel looks off.
I agree...I think it was so dirty that it stained the paint to the point of cleaning it to much. It is tan....just lighter plus some of the paint is coming off. I need to look into how to re color it.
My grill looks exactly like yours used to, all dark gray across the two middle bars. You're saying all you did was use some laquer thinner and it now looks brand new?
The thinner remover the two layers of factory paint....one dark gray color and one light gray primer layer. The grill was chrome under the paint. I could see the chrome shining under the pain in areas where it was worn or chipped a bit. You can see the original condition of my grill in the very first pic I posted. I used an old bath towel to wipe the paint off with the thinner.
I would guess if your grill has no chrome showing as an outer frame like mine did in the first pic, yours may not have any chrome under the paint.
The presence/absence of chrome on the grill has been discussed before, and there doesn't seem to be a consistent way to know unless the face is chipped or you wipe it down with a paint remover. Downside of using a paint remover is that if the chrome is not there, you're then obligated to repaint.
