50 Cent Mod
Old Aug 17, 2011 | 08:14 PM
ronjon95's Avatar
ronjon95
50 Cent Mod
I started the 50 Cent Mod this evening. I only got the driver side done. I really wish I would have done this sooner as easy as it was! I hope the passanger side is not to difficult. There should be a PIC!! Wow thats a really good PIC!! Now im hyped!
Old Aug 17, 2011 | 08:18 PM
clintbonnie's Avatar
clintbonnie
Good job Ron...!! that connector is secure now ! Passenger is not that bad.. go for it..
Old Aug 17, 2011 | 09:24 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Passenger side is a little tougher getting the bolt out between the valve cover and firewall and valve cover and a/c housing and those darn heater hoses being in the way but it wasnt that bad. It only took me a few more minutes to do over the drivers side.
Great pic!
Edit: you did remember to retorque the injector hold down bolts and the rocker arm bolts right?
Old Aug 18, 2011 | 02:17 AM
Persona's Avatar
Persona
Nice work...I just did both of mine a couple of weeks ago and it made a big difference.
Old Aug 18, 2011 | 02:48 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Soo.. whats the point of this? I know it keeps the connector in but I know nothing else..
Old Aug 18, 2011 | 05:33 AM
Franko72's Avatar
Franko72
Molon Labe
Thats the point of it...
You dont want the whole plug to wiggle loose while driving down the highway 6 hrs into a 12 hr trip trust me....just trust me.
Old Aug 18, 2011 | 05:53 AM
Crewcab Turbo's Avatar
Crewcab Turbo
I have been wanting to do this to mine. Are the valvecover gaskets reusable or do u have to get new? And what are the torque numbers for the rockers and injectors? Good pic! Thanks!
Old Aug 18, 2011 | 07:09 AM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig
Came to the party late. What is the 50 cent mod? I am reading that it holds some kind of connector and see that it takes a quarter for each side.
Old Aug 18, 2011 | 10:10 AM
clintbonnie
Here is the info you need..
https://www.ford-trucks.com/forums/8...ck-shakes.html
Also, it is a good idea to check the center pin while doing the fix.. it burns sometimes, caused by the loose connection.
And yes, the valve cover gaskets are re-usable..
Old Aug 18, 2011 | 12:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The only other thing they are for, is if the engine blows up, you can still say it's worth $.50
Old Aug 18, 2011 | 12:11 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Is this one of those things that Ford fixed down the road, or should I do this too? Mine is a 2002 and I have found that a lot of stuff on my truck has been fixed by Ford because its a later model 7.3.
Old Aug 18, 2011 | 12:18 PM
miller_feed
I don't remember the year ford fixed this, but my truck didn't have the clips. I did the Chris-50 to mine.
Old Aug 18, 2011 | 01:38 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Mine is a July 02 build and it did not have the upgraded clip holder thing-ma-jig. If you do the mod you will be able to retorque your injectors and rocker arms. Some here have said they noticed a big difference in noise, I didn't notice any.
Old Aug 18, 2011 | 01:42 PM
DND58's Avatar
DND58
Mines an 02 and did not have the clips. Drivers side was slightly loose. I'm confident the retorque helped quite down the motor, less rattle.
Old Aug 20, 2011 | 09:33 AM
Bobbys Big Red Rig
The guy I purchased my truck from had put new injectors in and did nod torque them. Figure I will do that, replace glow plugs, and throw in 50 cents while I am there.
