Sponsored by: Real Truck
2001 Hubs
Old Oct 13, 2012 | 07:35 PM
Fuzzynemo's Avatar
Fuzzynemo
2001 Hubs
Hello, new to the forum and have a question.
Just purchased a 2001 F250 4x4 with 7.3 and one of the manual locking hubs is bad. What is a good replacement and how will it look with the stock center caps?
Thanks.
Old Oct 13, 2012 | 09:49 PM
LabCab's Avatar
LabCab
Aftermarket you can either go with Warn, or Mile Marker. I have a set of new Mile Markers that I bought for my Excursion that I sold without ever installing them. I have seen several people upgrade to the newer front centercaps with Warn, or MM hubs as they don't stick out as far.
I have my hubs on Craigslist now, need to get them out to someone that can use them.
Pat
Old Oct 14, 2012 | 09:30 AM
dagren99's Avatar
dagren99
Is the hub stuck/hard to turn? or are the splines stripped? Stripped splines = new hub, stuck can usually be freed up. I still have stockers on my 00 and use 4WD nearly every day.
The stock hubs can be freed up when stuck by using a teflon based lubricant spray and cleaning them up.
Old Oct 14, 2012 | 09:43 AM
DetailerDave's Avatar
DetailerDave
I have manual hubs, and one is easy to turn, the other is stiff. I made a tool out of stainless steel to turn them. It makes it easy to lock/unlock with gloves on too.
Old Oct 14, 2012 | 09:50 AM
dagren99's Avatar
dagren99
I've been using a Dupont Teflon Spray on mine 2x year for 4-5 years and they are easy to turn - just spray around the edge of the **** @ each tire rotation and work them back and forth a few times. If mine ever strip I'll probably switch to Warns but I'm in no hurry.
Old Oct 14, 2012 | 04:55 PM
Fuzzynemo's Avatar
Fuzzynemo
LabCab, will your hubs fit 2001 f250? And what price you want for them?
Old Oct 14, 2012 | 05:08 PM
Fuzzynemo's Avatar
Fuzzynemo
Hub is stripped out. They are the OEM hubs.
Old Oct 15, 2012 | 10:49 AM
SteveH-CO's Avatar
SteveH-CO
Buy Milemarkers and get '05-style center caps (you can get repro ones on Amazon, I think). The hubs work well and look great with the shallow center caps. They look dorky and would be hard to use with the stock center caps, IMO.
Old Oct 15, 2012 | 01:10 PM
Fuzzynemo's Avatar
Fuzzynemo
Thanks Steve. Great info!!
Old Oct 15, 2012 | 03:50 PM
EXv10's Avatar
EXv10
Take your sticky hubs off, drill a very small hole in the recessed part of the dial. and soak them in ATF overnight. The o-ring can be replaced also.
bkeese
Oct 23, 2014 01:47 AM
RyCoy
Dec 8, 2012 01:14 PM
bullseye850
Apr 1, 2010 04:44 PM
mach2race
Jun 13, 2006 05:18 PM
saanders
1978 - 1996 Big Bronco
Feb 16, 2003 06:08 PM
