2002 Tow Rating Difference
Old Oct 13, 2012 | 01:27 PM
jh818's Avatar
jh818
I was looking up the tow ratings on the Ex's in Trailer Life for 2002 model year. It says for V10s, 10,500 lbs. for 4x2 with 4.30 gears, but 11,000 lbs. for 4x4 with 4.30 gears. Why the 500 lb. difference? 4x4 would be heavier than 4x2.
I am guessing it's the springs on 4x4 vs 4x2?
What do you all think?
Why am I asking? Just looking at travel trailers. We like this one with GVWR of 11,162 lbs.
2013 - CrossRoads - Zinger - ZT33BH - Travel Trailer - Middletown - OH - Details
Not that we are replacing our current trailer, but this one is sure nice and the price isn't that bad.
Old Oct 13, 2012 | 01:38 PM
Forest's Avatar
Forest
What are your spring codes? 4x4 has "G" code in rear. Look on drivers door label
What hitch platform do you have? 12500 lb or 10000 lb?
Old Oct 13, 2012 | 02:04 PM
wpnaes's Avatar
wpnaes
I recall one difference was the 14 vs. 18mm mounting bolt, but 2002's should have the same bolt size.
https://www.ford-trucks.com/forums/1...iii-or-iv.html
Old Oct 13, 2012 | 02:26 PM
jh818's Avatar
jh818
Spring code is HA. Hitch is 12,500 lbs. with WD hitch.
Old Oct 13, 2012 | 02:33 PM
Forest's Avatar
Forest
Then, you are probably correct. I have to assume the only difference is the spring rating on rear axle, "A" vs. "G" springs. I think the axle is the same, and the brakes should all be the same. Hitch is capable. My rear axle GAWR is 5,250 lb. What is yours?
Old Oct 13, 2012 | 02:38 PM
jh818's Avatar
jh818
5,250 lbs. also for GAWR for the rear.
Old Oct 13, 2012 | 02:44 PM
bergy 2000's Avatar
bergy 2000
The camper may have a gvwr of 11162 but dry weight is only 8370 lbs. I tow a Springdale 303 bhssr with my 2wd excursion for 2 years now and it pulls it and controls it great. It is similar in weight to the trailer you're looking at. The hitch weight is a little heavy but i think you will be ok if you load it right.
jh818's Avatar
jh818
Yup. I have the higher rating than the '00.
Old Oct 13, 2012 | 08:55 PM
Turfzilla's Avatar
Turfzilla
On topic semi hijack: How do read the tag on the rear diff to determine ratio?
MIne:
PM 409 D
L73 10 5 9 J13
Old Oct 13, 2012 | 10:25 PM
wpnaes's Avatar
wpnaes
Yeah, should probably start a new thread... or better yet do a quick search, there's plenty of info out there...coupla examples:
https://www.ford-trucks.com/forums/1...-rig-have.html
https://www.ford-trucks.com/forums/1...ear-ratio.html
Hesson81
All Things Towing
Feb 28, 2019 10:19 AM
retriever
Jan 23, 2010 03:31 PM
84-250
Jun 20, 2009 09:17 AM
trike1946
20
Mar 26, 2007 07:03 PM
silvercc
Mar 7, 2006 09:28 PM
