Member stranded (blue Mule)
Old Oct 12, 2012 | 09:25 AM
Action4478's Avatar
Action4478
Blue mule ( Rodney ) is stranded in Indiana ,I 70 At exit 154 @ the Illinois Indiana border .. Electric fuel conversion rail pump died , Replacement pump appears to be defective . Any members near that can lend a hand ?...
He can be reached 602-284-0170
Old Oct 12, 2012 | 10:06 AM
Action4478's Avatar
Action4478
TTT............
Old Oct 12, 2012 | 10:38 AM
ralleyclimber's Avatar
ralleyclimber
Sorry I'm in Utah. Knowing the people on here. I'm sure someone will turn up to help out
Old Oct 12, 2012 | 11:18 AM
1fixitman's Avatar
1fixitman
Augusta, GA here. Bump
Old Oct 12, 2012 | 11:28 AM
Tugly's Avatar
Tugly
If I could I would... I even have a working used pump on my bench.
Bump
Old Oct 12, 2012 | 11:59 AM
Action4478's Avatar
Action4478
Testing of two replacement pumps using a can of fuel with a hose to the pumps , they run ,but no draw or pressure ...
Old Oct 12, 2012 | 12:11 PM
Tugly's Avatar
Tugly
That sounds like you have a bad seal on the line to the can/tank... unless your pumps are not self-priming. What are the pumps? I can look into this.
Old Oct 12, 2012 | 12:26 PM
Action4478's Avatar
Action4478
He tried the first replacement pump by installing it to the original lines on the truck , put 12V to it no go , reversed it ,still no go . Second Auto zone pump , hooked to an independent fuel source to rule out tanks , still no go after filling it with fuel first ..
Old Oct 12, 2012 | 12:47 PM
Tugly's Avatar
Tugly
  1. Do you have make/model on the replacement pumps?
  2. If I understand this, you're using the original quick-disconnects? Can you run a straight hose without the QD?
  3. The polarity of the original pump was pretty much set by the connector sizes, were the connectors replaced? I'm wondering if it's running backwards.
* Edit* I just saw that you reversed the electrical for a test. I couldn't do that with my stock pump without cutting the connectors.
Old Oct 12, 2012 | 12:48 PM
CSIPSD's Avatar
CSIPSD
Sounds like the pickup is plugged or the tank switching valve is stuck...
Old Oct 12, 2012 | 01:06 PM
Tugly's Avatar
Tugly
Originally Posted by CSIPSD
Sounds like...switching valve is stuck...
Good catch, I fell asleep at the "switch" on that one.
Old Oct 12, 2012 | 01:44 PM
SkySkiJason's Avatar
SkySkiJason
Hit it with a hammer.
Seriously. My last AZ (Airtex) pump didn't work on install and after doing ALOT of other stuff I gave it a few whacks. Its been working ever since...
Old Oct 12, 2012 | 02:02 PM
Action4478's Avatar
Action4478
He bypassed the tank switch & tanks by using a hose & a can of fuel ..It starts now but won't stay running . I think air in the system ..
Old Oct 12, 2012 | 02:17 PM
1fixitman's Avatar
1fixitman
If he still has the original strainer in the tank then maybe he can get some compressed air from a can or someone and blow into the suction line for the tank and blow the screens out I don't know if he has done the hutch mod so just bumping and maybe he can get some compressed air.
Dwayne
Old Oct 12, 2012 | 02:26 PM
Tugly's Avatar
Tugly
I cycled the pump about 3 times (key on, key off, repeat) without starting after draining the fuel lines to get the fuel up there again. There's also the possibility something else is at play. Did you open the fuel bowl drain valve to see what's going on? Foam, or fuel? Quality of fuel?
