Sponsored by: Auxito
Transmission trouble
Old Oct 9, 2012 | 05:34 PM
DocEdison's Avatar
DocEdison
Hi, new here. I have 2001 F-150 2wd w/v6 and OD automatic. All of a sudden I have no reverse and while in od will not shift into od. If I turn off od it shifts fine but still have no reverse. Any help? I want my truck back!!! Thanks for any help!
Old Oct 9, 2012 | 08:20 PM
Bluegrass 7's Avatar
Bluegrass 7
Does the OD light flash?
Are there any codes set?
Old Oct 22, 2012 | 05:17 PM
DocEdison's Avatar
DocEdison
Hi thnx for replying. No OD lights does not flash. No codes that I know of.
Old Oct 22, 2012 | 05:57 PM
jk080's Avatar
jk080
Transmission Rebuilder
That truck should have the 4R70W transmission in it, this transmission is notorious for a broken sun gear shell. When this shell is broken you will loose second, fourth and reverse.
Sorry but it sounds like this transmission will have to be removed to be repaired.
Old Oct 22, 2012 | 06:02 PM
Bluegrass 7
If the OD lamp does not flash signaling a fault is present, then you need a good trans shop to look at the situation.
Reverse is a total manuel action with the shift linkage.
There is no shift solenoid involved except the pressure control for all operations, for reverse since it's only one gear and never upshifts or down shifts.
Be sure the shift selector is not out of adjustment and connecting rod is in good shape.
curiousv
1997 - 2003 F150
Jun 5, 2018 01:48 AM
Treacy
Aug 15, 2017 05:41 PM
gtstill
1983 - 2012 Ranger & B-Series
Jan 18, 2017 07:04 PM
FormerJeeper
Feb 14, 2012 03:03 PM
enos
Jul 7, 2003 08:16 PM
