OK, when you push the horn button, you ground out a wire, which is attached to a relay. That relay energizes, causing power to flow to your horn and the horn itself to produce loud noise. Obviously, there is also a second ground path that energizes the horn when you lock the doors with the remote. Either the relay is stuck, or the input lead is grounded somewhere it isn't supposed to be grounded.
A blown fuse will not make your horn blow continuously, HOWEVER it will make your horn stop working.
If your cruise control works, then the clock spring probably isn't the issue, but there is still a slight chance it could be the clock spring.
cruise control works. I'm guessing it is the relay.
thinking back over the last couple days. I do recall smelling a very faint "electric burning" smell the day after my horn was stuck. smell is gone now, but perhaps that was related. (or perhaps not, that was also coincidentally the first day I had the heat on on the truck since spring. could have been dust in the heat system smelling)
If the cruise control works, its not the fuse correct?
Thanks for the suggestions!
The cruise control is probably protected by a separate fuse. The burning smell was probably related.
They replaced the horn fuse and the horn works, but only the high-tone.
The dealer wants to replace the horn and the Central Junction Box.
If the horn is working fine now. Doesn't blow a fuse, but the low-tone isn't working... I'm wondering if the odds are the horn (low tone) is what shorted out and blew the fuse and the relay is fine.
Seems to me if the horn continues to work fine (high-tone only) I should just replace the horn and not spend the extra $500 on the CJB (part and labor)
Seem logical?
Second question, how hard it is to get at the horn to replace it?
Hi, did you ever figure out what was wrong with the low tone horn? Mine is doing the same thing, high tone works, low tone doesn't. Actually, the low tone horn works for a couple weeks then doesn't. Any ideas? Is it just the low tone horn or is there something else going on?
