horn don't work
Old Dec 15, 2005 | 08:33 PM
HENDEL JR's Avatar
HENDEL JR
Question horn don't work
this is 1990 ford e-150 5.0 302
this has the speed controls on the horn pad
does this have to with the turn signal assembly
im just gues or does haved with the speed control amplifier
all this stuff bult in to the horn relay and relay is good
am not getting no curent
Old Dec 15, 2005 | 11:38 PM
pfogle's Avatar
pfogle
Okay, test the switches in the horn pad. It's held on with two screws. Get an ohms meter and check the resistance across the the terminals.
Old Dec 16, 2005 | 07:44 PM
mhg's Avatar
mhg
first check the fuse
always the easiest things first
on this year it is possible that horn and cruise is tied together
check horn relay to rule out this as a bad part and also the horn its self
Old Dec 17, 2005 | 03:17 PM
HENDEL JR's Avatar
HENDEL JR
THE HORN AND CRUISE ARE TIED TOGETHER BUT STILL I CAN GET NO 12VS
TO THE STEERING WHEEL WOULD THE TURN SIGNAL ASSMBLY WOULD HAVE
SOMTHING DO WITH IT OR NOT I NOW THE HORN WORKS
BUT IT WONT WORK FROM THE HORN BUTTON
Old Dec 17, 2005 | 11:39 PM
Crash687's Avatar
Crash687
if all else fails you could always get the plate that states "Horn broke, watch for finger"
Old Dec 18, 2005 | 12:08 PM
pfogle's Avatar
pfogle
The turn signal switch shouldn't effect it. It sounds like you have a bad connection in the connector on the steering column. If that's not it check all your fuses and relays.
Old Dec 24, 2005 | 12:26 PM
Heavy460's Avatar
Heavy460
You can do what the last owner of my van did.Rip it out and put a air horn in.
Old Jan 3, 2006 | 05:29 PM
Eco?noline's Avatar
Eco?noline
If your '90 is wired the same way as mine '93 and the horn isn't working, but the cruisecontrol is working fine, then you have to check the small circuit of the horn relay (the switched side) and the horn it self.
Because the cruisecontrol get his current thru the coil of the horn relay, 4 of the 5 functions use this current.
Is the cruisecontrol also down, then check the voltage at both sides of the relay coil, this should be about your battery voltage, if this is the case check the same wire at the steering wheel on both sides of the clockspring (the clockspring could be broken).
In fact, as long as you have current on this wire, it's ok, if you don't, start searching from the last point you had.
Rudi
Old Jan 6, 2006 | 05:54 PM
HENDEL JR's Avatar
HENDEL JR
Rudi
what is a clockspring you are right the speed contral is
in with the horn i went down to advance auto parts store
i put a new relay in but now the horn works but when you press down on
speed control button the horn blows could be because i put a horn relay
from another year van like 1985 witch part was cheaper
Old Jan 6, 2006 | 05:55 PM
HENDEL JR's Avatar
HENDEL JR
Old Jan 6, 2006 | 06:10 PM
Eco?noline's Avatar
Eco?noline
The clockspring is the connecting part between the steering column and the steering wheel, it's a kind of flatcable wound up like a clockspring.
I don't know if the '90 model has one, the '92 and up models do.
If the horn does work again with the horn buttons but also with the cruise control buttons, i guess the resistor of the new horn relay coil is not within specs.
Because the coil is in serial with the cruise control functions, the balans beteen these is not good anymore.
Swap the relais with another original one in the fusebox, this has to solve the problem, otherwise there is a bad connection or so.
Rudi
nailerdog
35
Jul 31, 2024 01:46 AM
Rasty1
Sep 18, 2016 01:01 PM
BigBore44
Nov 13, 2015 01:42 PM
mdbbrown
Jan 17, 2013 12:22 PM
Truck451
1978 - 1996 Big Bronco
Oct 26, 2010 05:10 PM
