Duraspark or Pertronix
Old Oct 13, 2012 | 01:57 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
All the FE motors (what you have) had a 1/4 inch oil pump driveshaft, the only ones that got a bigger one were the industrial series called the FT. The only trucks that got those engines were heavy duty ones. But I suppose someone could have swapped one in, but it isn't likely. To make sure you could pull the distributor out and measure the hex key in the bottom.
I might have to get one of those HEI units, that does look too good to be true! I like the idea of opening up the plug gap, I have a friend with a 460 and a HEI on it and it runs nice!
Sam
Old Oct 13, 2012 | 02:01 PM
cjohn2000's Avatar
cjohn2000
Thanks, that makes sense. I figure its not been swapped its a pretty stock truck, original owner had it to 2002 to according to the former owner who bought it from a dealer lot in 2002, but you never know.
Old Oct 13, 2012 | 03:57 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
No secret I'm a fan of Duraspark. Pertronix point replacement module will solve your point problem at a reasonable price. The GM technology HEI system would be my last choice. Fitment problems can arise with air cleaners, even the hood on some vehicles. E-Bay Chinese manufactured units have been known to break their shaft and wipe out an engine. But, just my opinion. Good luck whichever you choose.
Old Oct 13, 2012 | 06:30 PM
1972RedNeck's Avatar
1972RedNeck
The chinese coils are junk, and the modules are just as bad. If i were going to use HEI I would look into a DUI (Davis Unified Ignition) unit.
Old Oct 14, 2012 | 05:43 AM
williamwilliam's Avatar
williamwilliam
Everyone has their opinions. I thought it was too good to be true too. I havent had one problem with mine since I installed it a year ago. Fires right up everytime. Took me about 30 minutes to install, and that was taking my time. As long as you put a 2 inch spacer between the carb and intake ($20) your golden, which is a good idea to do anyway because your carb doesnt get as hot. Even the stock air cleaner will fit after installing the spacer. IT IS NO WHERE NEAR THE HOOD! I am running a 4 inch tall chrome air cleaner and it has plenty of room.
Pertronix is good too, but you cant go in any store and buy a pertronix unit if it goes bad. All parts stores have all the replacement parts that are under the cap of this HEI unit.
Duraspark is good, but to many wires dangling under the hood. HEI is a much cleaner install. Here is the unit I got from CRT Performance, I would go with them if you decide to do so. Very good quality as well and worth every penny.
FORD FE HEI Distributor 332,352,360,390,406,410,427,428 + 8mm Spark Plug wires | eBay
Here is a 4B spacer that I got, although you might have to find a 2B if thats what you have on your truck right now:
http://www.ebay.com/itm/6008-2-THICK...bc0205&vxp=mtr
Old Oct 14, 2012 | 10:52 AM
willowbilly3's Avatar
willowbilly3
Petronix is simple and the only one I ever installed is still running fine 6 years later. BUT, for my money, I would go with the Durspark II Distributor, efi coil and GM module. It's easy to wire up and the coil gets full 12 volts. I did that on my 92 300-6 and it's the best system I've had, plus I scrounged all the parts so it cost zip and all the parts are easy to find and readily available if you ever need a replacement.
Old Oct 14, 2012 | 03:40 PM
williamwilliam
Yeah, I have pertronix in 2 of my 69 mach 1's and they are about 6 years old now. But if I ever do go another route, I would put the same HEI unit that I put in my truck in my 2 mustangs. $139 for the dizzy and 8mm wires is a great deal. The HEI gets a full 12V too . Huge difference when I went from points to the HEI..........I cant complain.
Old Oct 15, 2012 | 08:51 PM
cjohn2000's Avatar
cjohn2000
#6008 2" THICK ALUMINUM CARBURETOR SPACER-HOLLEY/CARTER (u) | eBay
Heres the distributor I ended up getting. I tried to get one from a somewhat reputable dealer on ebay. Air Cleaner? Pretty rusty from water sitting on it in its past life. Just got the rubber piece for the firewall to hood from LMC.
Old Oct 16, 2012 | 04:55 AM
williamwilliam
Where is the dizzy you got? Link?
Old Oct 16, 2012 | 11:04 AM
mr. wackodog's Avatar
mr. wackodog
has any one tried the duraspark from DUI?
Old Oct 16, 2012 | 11:01 PM
cjohn2000's Avatar
cjohn2000
FORD FE 352 360 390 427 428 HEI DISTRIBUTOR BBF | eBay
Old Oct 18, 2012 | 11:50 PM
cjohn2000's Avatar
cjohn2000
Got my HEI dizzy today for the 390 . Man that thing is big. Been looking around saw that frozen distributors on 390FE's is common, also possible to pull the oil pump drive shaft out? I got the distributor moving somewhat free, probably 120 degrees back and forth, enough to set timing. I also read that under the points plate theres a spot to get a wrench on to turn the housing. Anyway my big fear is pulling the oil pump drive shaft. Anyone have any experience or ideas? Thanks, Corey
Old Oct 19, 2012 | 08:58 AM
  #28
MIKES 68 F100's Avatar
MIKES 68 F100
only reason shaft comes out is if someone rebuilt motor and didn't put the retainer back on the shaft . so it's just pull dizzy and see what happens .
i've been lucky with a 289 and shaft stayed in dizzy and i was able to grab it before it fell out and dropped to bottom of pan . i used a magnetic 1/4 nut driver to install it .
Old Oct 19, 2012 | 09:20 AM
  #29
cjohn2000's Avatar
cjohn2000
ok, thanks.
Old Oct 19, 2012 | 12:51 PM
  #30
williamwilliam
Yeah, I have pulled a many out and never had that happen.....knock on wood! I think you will be ok, just take your time when pulling it out.
