Im stumped
Old Oct 12, 2012 | 09:06 AM
blueline970's Avatar
blueline970
Well I did bubble test and didn't see any. Runs pretty smooth when cold but gets worse when warm. Guess would hurt to go ahead and check them.
Old Oct 12, 2012 | 09:35 AM
BLADE35's Avatar
BLADE35
get it hot and Ohm the Inject coils out
Old Oct 12, 2012 | 05:02 PM
blueline970
Ok got it to operating temp and I was getting .8 ohm all around.
Old Oct 13, 2012 | 02:25 PM
blueline970
Would it probably be a good idea to go ahead and pull out the injector harness and open it up and take a closer look at it? I took the harness out when replacing HPOP.
Old Oct 13, 2012 | 02:43 PM
BLADE35's Avatar
BLADE35
Ok good They should be 4 ohms or less so 0.8ohm is Good
The Coils also should be Open to Each Other
You can also check the Harness for continuity and should Load Test #7 harness
Old Oct 13, 2012 | 03:11 PM
blueline970
How do I load test it?
Old Oct 13, 2012 | 03:19 PM
blueline970
Well I pulled my harness and the #7 plug has crimp connectors on it under the cover and tape. Is that factory or someone before me jacking with it?
Old Oct 13, 2012 | 03:23 PM
blueline970
Found a spot where the insulation is split open.
Old Oct 14, 2012 | 01:30 AM
BLADE35's Avatar
BLADE35
High Beam Lamp and use the Battery to give it power threw the wires
You can continuity threw it too
it could be having issues in either spot
I havent pulled mine apart yet but would think somebody fixed it at the crimp connectors does it look like it rubs something there
Pretty good Odds your Harness is the Issue
Take a DVM check for continuity threw those 4 wires even wiggle it around during the test so if you Lose continuity
Old Oct 14, 2012 | 10:06 AM
nitrogen's Avatar
nitrogen
crimp connectors are spawn of the devil. they can be ok if you have one of the compound crimping tools and you use the heat shrink crimp terminals. my personal choice is soldier and heat shrink. i have opened up too much stuff only to see the wires pull right out of the crappy crimp just by finger pressure.
Old Oct 14, 2012 | 10:37 AM
blueline970
I went and head and replaced the crimp connectors with the ones that have the heat shrink with them. I also repaired a couple spots that had split insulation. Seems to run better. Still getting a miss fire count on the number 7. Number 5 wasnt acting up today. Cleared my codes and still getting the contribution on 5. Will check later on for more codes. Also still getting blue smoke from the exhaust. My CCV is throwing lots of oil into the intake which I never had a problem with before.
bike_guy123
Nov 20, 2014 01:21 PM
Jrylmon
Sep 2, 2013 08:09 PM
gratcliffe
May 15, 2013 12:21 PM
cowboykb
17
Dec 14, 2011 10:31 PM
MagKarl
27
Jul 19, 2007 08:49 PM
