Ok I have a 2004 early build. Truck was running good until HPOP went out. I replaced it along with oil cooler. It's running now but I get a P0275 contribution. Noticeable smoke from exhaust. Smoke is kind of white to light grey. Noticed while driving from 50 to 60 mph it has a stutter.
I have checked continuity on the injector harness to #5. The plugs are in good to ficm and injector. FICM hasn't dropped below 46v. ICP and batteries are less then year old. Also getting a lot of oil from ccv which I never had an noticeable oil before pump change. What should I look at?
Most likely you have a leaking or failed injector. You might pull the secondary fuel filter and fuel pump fuse and have somebody crank the truck while you watch for bubbles in the filter housing, which would indicate a leaking injector.
Well I don't have AE but I have a mechanic friend that said I could run by his shop and do it. Gives him a chance to use his new scan tool since his last one was stolen.
Ok wasn't able to get my contribution test done but I noticed something on my scanner today. The cylinder miss fire count was going off on 5 and 7. 7 was much higher then 5. What would this tell me? Bad injector seal or .......?
Going to try and get it over to a place and get the contribution test tomorrow.
Ok did bubble test didn't see any thing. Had the old fuel pressure spring and upgraded to blue spring. Seems to idle smoother but still lacking a little get up and go.
I'm getting oil from ccv into my intake and don't have white smoke its a light bluish smoke. I have noticed that between 1500 to 2000 rpm it doesn't like that range especially when going down highway from 50 to 60 mph.
I'll check codes again tomorrow. Any other thing I may need to check? I know my ICP wasn't leaking oil when I replaced the HPOP. I replaced that less than year ago.I'm sure I missed something.
Been reading and I'm wondering about this check valve that is on the high pressure oil rail. Does anyone know anything about it?
A check valve AKA standpipe would affect the whole injector bank, not just one or two cylinders. I'm thinking leaking injector since the codes indicate the cylinders are next to each other. You need to pull the back two passenger side injectors to see what's going on.
