How do I adjust the lash in the diff
Old Oct 8, 2012 | 07:22 AM
ltl_jrw's Avatar
ltl_jrw
I have some play in the third member (99 F350) and was wondering if there is a way to adjust the grear lash while in the truck. I was told there is a crush sleeve and I could just tighen the yoke nut is this true?
Old Oct 8, 2012 | 07:59 AM
mueckster's Avatar
mueckster
What kind of play are you referring to? Pinion twist, up & down, or in & out? Tightening the nut adjusts the pinion bearing preload. Overtightening can lead to bearing failure. Gear mesh is adjusted with shims behind the pinion gear and behind the differential housing carrier bearing races.
Old Oct 8, 2012 | 08:03 AM
Snowseeker's Avatar
Snowseeker
No.
There is a sequence of how things are assembled and set in the rear end.
I am sorry I am not a gear guru but I do know some (set up a couple rear ends).
The pinion is set to depth to contact the center of the ring gear teeth, then the lash is adjusted out by the carrier bearing shims/nuts.
Just don't start turning nuts and bolts in the rear end.
Old Oct 8, 2012 | 06:13 PM
ltl_jrw's Avatar
ltl_jrw
Thanks guys, I have some twist in the pinion, can I just tighten the yoke nut some and take out some of the slack?
Old Oct 8, 2012 | 06:23 PM
Kdr358's Avatar
Kdr358
I would take it to a pro unless you have the tools and experience to tackle it.
Old Oct 8, 2012 | 06:55 PM
Crewcab Turbo's Avatar
Crewcab Turbo
If you have twist in on your pinion then you have bad pinion bearings, or lots of wear on the ring and pinion. Tightening the pinion nut will not make things better. Loose is wear. Unfortunately there's gona be a new ring and pinion and bearings in your future.
Old Oct 8, 2012 | 07:14 PM
crop harvester's Avatar
crop harvester
better off to not touch it until your ready to rebuild it.
Old Oct 8, 2012 | 07:17 PM
Kdr358's Avatar
Kdr358
If you catch it early you might be able to get away with just a set of bearings.
Old Oct 8, 2012 | 08:37 PM
Snowseeker's Avatar
Snowseeker
Quite possibly, wait to long and it will wear the gears funny.
Old Oct 8, 2012 | 08:52 PM
mec500's Avatar
mec500
is the pinion loose and move up and down or just twist an 1/8 turn back and forth .if the bearings are tight that twist is normal your feeling the slop from the pinion through the spider gears to the axles .before you go and tighten anything pull the cover and look inside back lash is the clearence between the gear teeth and is adjusted by moving the ring gear closer or farther away from the pinion using shims .if there is up and down pinion slop your seal is probly leaking? then your most likley need to replace all bearings a master overhaul kit is about 250
Old Oct 9, 2012 | 04:46 AM
ltl_jrw's Avatar
ltl_jrw
I have about a 1/8 twist but no up or down. So that is suppose to be normal?
Old Oct 9, 2012 | 06:52 AM
Calli's Avatar
Calli
Slip joint regreasing
Actually i/8 twist is probably about right. You will have some slop of the gears. You may be feeling the clunk in the driveshaft where the splines connect. They need to be greased from time to time.
Do search under (slip joint regreasing)
Old Oct 9, 2012 | 08:45 AM
mec500's Avatar
mec500
thats normal. for peace of mind you could pull cover and sweep around with a magnet if no chuncks or flakes run it
aidandj
Nov 25, 2015 02:40 PM
mortstang
Mar 12, 2010 05:10 PM
Minger
Jan 13, 2007 10:00 AM
therigwelder
May 27, 2005 07:24 AM
Dayak
Jan 22, 2005 06:04 AM
