Problems with 4x4 system (Help)
Old Oct 7, 2012 | 10:55 PM
grandall1983's Avatar
grandall1983
- 1994 F150
- 5.0l Automatic
- Cruise Control (Works)
- Push Button 4wd
- Nothing happening when 4x4 button pressed
- No light comes on
- no sound heard
- Fuses are good, can't about large one yet until I test it.
- Connection on the backside of the button switch is good.
I've been looking non-stop and really don't want to start another thread, but I really just want answers.
Questions
1. How likely is it that the switch has failed?
2. Does anyone have a link to a good step by step diagnosis. One with good pictures would be nice.
3. How do I find the shift control module to self test it?
4. What all should I be looking for and what if anything under the hood should I look for?
Any help will be greatly appreciated.
Thank you,
Old Oct 8, 2012 | 12:30 PM
Phy's Avatar
Phy
Search this forum and the Bronco forum for electric transfer case shift or push button transfer case, and you should find lots of reading...
Old Oct 8, 2012 | 12:31 PM
dixie460's Avatar
dixie460
Originally Posted by grandall1983
- 1994 F150
- 5.0l Automatic
- Push Button 4wd
- No light comes on
- no sound heard
Questions
Not likely, but possible.
Start with the shift controller self-test.
Behind pass. side kickpanel.
Wherever the self-test codes point you.
It's common for the position encoder on the shift motor to crap out. Search for a how-to on repairing or replacing it.
Thank you,
See comments above. See if you get any codes back from the controller.
Old Oct 8, 2012 | 05:10 PM
grandall1983
- I tested the shift control module.
- I Disconnected B and C and fallowed the online instructions.
- I got a normal result 4 blinks from the LED Light.
- Where should I check next?
- Right now, I know there is nothing happening according to the web posting I am reading I have a dead system.
I am going to replace the one large fuse I can not tell if it is good or not, then what would be next?
Thanks for the help so far.
Old Oct 8, 2012 | 05:57 PM
danr1's Avatar
danr1
See,
1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
Should prove to guide you doping out the problem fairly quick.
Old Oct 8, 2012 | 07:08 PM
grandall1983
Originally Posted by danr1
See,
That"s what I have been using so far, but after looking at the fuses and the shift control module, I am a little lost. Nothing is showing me red flags.
I have yet to find a reason why no lights are coming on and the system is acting completely dead. Just working as hard as I can on it.
I have manual locking hubs if that helps at all.
Thanks for the input.
Old Oct 8, 2012 | 08:07 PM
danr1's Avatar
danr1
Did you scroll down to and follow the,
Nothing Happens (Dead System) (diagnosis section).
aspect of that bulletin?
It outlines what to check and how to check what order to do so in.
From testing fuses, neutral safety switch to checking the lamps themselves etc etc.
You could try the basic tired and true vibrate the shift motor with a hammer couple times while someone hits the button trick but the fact nothing happens at all suggests a power supply issue of some sort rather then a stuck shift motor. Hammer trick usually comes into play when lamp lights then only flashes, that signifying motor got the message but didn't act or didn't move as far as commanded do so. likely reason no one suggested it so far.
Below is linked to from that page, perhaps you didn't see it. Should also prove to help if you don't have that information.
1983 Ford Bronco Diagrams picture | SuperMotors.net
navigatorstang
13
Jan 12, 2011 12:12 PM
LJF63
1978 - 1996 Big Bronco
Aug 22, 2006 06:42 PM
dallas lewis
13
Jan 6, 2006 07:13 AM
Brett W 55 Ford
1983 - 2012 Ranger & B-Series
Dec 30, 2005 01:06 PM
phonebooth
Sep 1, 2005 08:55 PM
