Starting issue 351w
Old Oct 6, 2012 | 10:30 AM
Shwan_89HD's Avatar
Shwan_89HD
Starting issue 351w
When i first start up my truck it starts up fine, but if i shut it off for a minute or 2 then start it up again, it starts pretty bad, fires up at first crank but its a long crank...What could this be? The alternator goin bad?
Old Oct 6, 2012 | 12:08 PM
subford's Avatar
subford
No it would not be the alternator.
Do you have black smoke when it starts?
If so, try holding the throttle on the floor while cranking and see if it starts faster.
Old Oct 6, 2012 | 02:35 PM
Shwan_89HD's Avatar
Shwan_89HD
No theres no smoke at all, it starts fine in the 1st jump but when you drive for a while and shut it off for a minute or 2, and start it again the crank is slow but will turn eventually
Old Oct 6, 2012 | 02:42 PM
khadma's Avatar
khadma
Carpenter Local 745
When was the last tune up?
Can you share some history of known maintenance?
Old Oct 6, 2012 | 03:29 PM
bashby's Avatar
bashby
If it is cranking slow when hot there is a good chance your starter is bad.
Old Oct 6, 2012 | 04:53 PM
Shwan_89HD's Avatar
Shwan_89HD
Ya only when its hot it starts like that
Old Oct 7, 2012 | 10:23 PM
951504x4's Avatar
951504x4
I had a very similar problem except mine would not start on the second go around. Ive had plugs, cap, rotor, wires, fuel pump, etc all replaced. Turned out to be the starter. Got that switched out and have not had a problem since. The guys are right with it not starting when its warm. Dont know why that is though.
Old Oct 7, 2012 | 10:37 PM
GNR22's Avatar
GNR22
I'm going to say it's your starter. I had the same problem with my truck about a year ago. It wasn't sudden though, it was slowly getting worse. I think it occurs when it's hot because the starter gets warm and doesn't work well that way.
Old Oct 8, 2012 | 01:26 AM
GoinBoarding's Avatar
GoinBoarding
Electrical resistance rises with temperature. So if you have a starter on the fritz, then it gets hot/warm, the resistance is high enough that the current can't flow to normal starting levels, and you get a weak cranking. Things cool off, and your starter thats about to die anyway, seems ok to you. Really though, when you put a new one on, you'll be surprised how slow it was cranking even when you thought it was OK. Check connections first though..
Old Oct 8, 2012 | 11:17 AM
1_ton_bronco's Avatar
1_ton_bronco
Weak starter and a tune up is needed.. Cant believe its like $55 for a tune up from rock auto.. lol
Old Oct 8, 2012 | 05:40 PM
BRay09's Avatar
BRay09
If the starter is cranking the same, hot or cold, it's not the starter. I'd bet it's the ignition module getting hot and not allowing it to start when warm. Or its timing is to far advanced causing a hard crank...
RedDevil460
Sep 20, 2013 07:52 PM
BuckHammer
138
Jan 10, 2013 09:23 PM
the winemaker
Oct 18, 2010 07:24 PM
jlsdcen2
2004 - 2008 F150
Oct 20, 2009 12:02 AM
phillips91
May 2, 2008 02:46 PM
