4x4 Indicator Question
Old Oct 5, 2012 | 05:38 PM
Nabors's Avatar
Nabors
Hey guys,
I was wondering if the 2000 f250's had a 4 wheel high indicator light? I got this about a month ago and a just got new hubs. I went in the yard and shifted the floor 4x4 into 4-hi but there was no light. When I shifted it into low, the 4-low light was on. Is this normal?
Old Oct 5, 2012 | 05:43 PM
Punisher29073's Avatar
Punisher29073
I have the electronic shifter but there is a light for 4 hi too.
Ryan
Old Oct 5, 2012 | 05:58 PM
Nabors's Avatar
Nabors
Is there a fuse or something for the lights? When I turn the ignition to the "on" position without starting the truck there are no lights that pop up for 4x4 or even the low range light. When I actually start the truck and put it in low range, the light comes on. I hear the transfer case actually shifting (an XL with manual 4x4 shifter) but the lights don't come on. Is there something actually on the t-case that tells the computer that it's in 4x4?
Old Oct 5, 2012 | 06:35 PM
Christof13T's Avatar
Christof13T
Pull your instrument cluster and check to see if the bulb is burnt out. Light isnt comin on... so start there and work backwards. I bet the bulb is burnt.
If the bulb is good... then maybe you do have an issue elsewhere... but no light at key on tells me burnt bulb.
Xtof
Old Oct 5, 2012 | 06:39 PM
Nabors's Avatar
Nabors
Thanks! I will check that. Something I forgot to mention is while doing this I never locked the hubs. Would they have to be locked for any idication?
Old Oct 5, 2012 | 06:48 PM
Punisher29073
Hubs won't matter.
Ryan
Old Oct 6, 2012 | 04:26 PM
Nabors's Avatar
Nabors
Checked 4x4 and everything works. That's what I was really worried about. I'll go through the lights and electronics sometime soon. Thanks for your help!
murph_murphy
1978 - 1996 Big Bronco
Apr 7, 2011 06:22 PM
fordbroncodave
Sep 11, 2009 12:35 AM
milk123
Dec 29, 2008 11:34 AM
FastMag
2004 - 2008 F150
13
Dec 18, 2008 08:35 PM
