driveline
Old Oct 5, 2012 | 01:13 PM
Ridenred333's Avatar
Ridenred333
driveline
quick question, where the front driveline goes into the axle housing my explorer is leaking oil. Is this hard to fix for a diy er or do the seals and and stuff need to be pressed in, and better for me to take it to shop.
Old Oct 7, 2012 | 07:11 PM
Ridenred333
Bump!!!!!!
Old Oct 8, 2012 | 07:05 PM
SBV45's Avatar
SBV45
Are you talking about where the front drive shaft goes into the front diff? that should be easy for a DIY.
Old Oct 19, 2012 | 10:27 AM
Ridenred333
Yes, i have never done it before so i was positive.
Old Oct 20, 2012 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
IF you are talking about taking off a lock nut that holds a u-joint yoke to the shaft, i woul dthink twice. The nut crushes a sleeve and sets the preload on pinion bearings and pinion depth.
jplinville
Oct 17, 2016 08:41 PM
F150-4-Life
Jun 26, 2010 03:36 PM
Reb2973
1997 - 2003 F150
Aug 30, 2007 03:22 PM
dean307
Nov 27, 2006 10:56 AM
Taasman
Apr 24, 2004 04:43 PM
