My 70 has a carter auto choke carb on it that the previous owner put on. I have noticed lately since its been getting cold here in colorado, that its harder to start in the mornings.
I was debating on switching the current carb to a c666 with manual choke.
It's electric isn't it? You said auto right? If so there are 3 screws holding the black housing on with a thin clamp all around it. Loosen the 3 screws and rotate the housing in the direction the arrow points to close it some. When set right pump the gas a couple of times. Hold it open about a 1/3rd and crank her up. This all assumes the choke is in working order. Ya do the same if it is not electric and is operated with a heat riser pipe as in factory stock. But you said it had an aftermarket carb. Right?
Yes oem replacement carter carb with auto choke. I think the spring is worn because I have noticed it closing sometimes while cruising. Would a manual choke conversion be the way to go? Found one for $12 I can put on.
