predator carb
Old Oct 5, 2012 | 04:39 AM
DieselDowdy's Avatar
DieselDowdy
predator carb
so im having problems with linkage hook up and i need some advice or guidance. the problem here is i run an E4OD with a standalone computer and the tps needs to be mounted to the throttle linkage some how and .....the current carb is a holley and computer company sells the mounting kit for the tps but it dont work with the Predator i was wondering if anyone else has had this issue andif so how the set up there linkages ?
Old Oct 11, 2012 | 10:40 AM
LxMan1's Avatar
LxMan1
Is this for a pull truck? The predator carbs are very picky about air temp, etc.
You will probably have to fabricate a custom mount to use a TPS.
Old Oct 11, 2012 | 10:49 AM
DieselDowdy
It's not for a pull truck just a mud toy . I had a Holley on it but it doesn't do well after 15 degrees of angle
Old Oct 11, 2012 | 03:49 PM
LxMan1's Avatar
LxMan1
It might work for that.
Old Oct 11, 2012 | 11:40 PM
DieselDowdy
I hope so this thing is becoming a pain to fab stuff for gotta fab this gotta fab that . Not fun when there's almost no following for this product don't get me wrong Im more then impressed with it it just sucks that there's only a small handful of people that have anything to do production of parts for these things .
Old Oct 12, 2012 | 07:07 PM
LxMan1's Avatar
LxMan1
Yeah, they were popular in the late 80's, early 90's. A friend of mine had a pair on a 55 Chevy with a 871 blown 502 in it. I was tuning a pair of them in. It was late afternoon and as the sun went down and the temp dropped, I had to keep messing with the mixture to keep it running right.
We finally gave up and went with 2 750cfm Holley's and once I got them happy, never had to mess with it again.
You may have better luck on a non supercharged application that doesn't have a .800 lift roller cam in it.
DieselDowdy
Sep 19, 2012 12:58 AM
chop block
Feb 15, 2011 10:10 PM
DELBERT
Jul 22, 2006 11:04 PM
wyldstallyn73
Offroad & 4x4
13
May 18, 2004 05:21 AM
Darryl
Mar 12, 2000 09:26 PM
