Please help! I am changing my timing gear assy and can't get the damper bolt out.
Is it left hand threads?
I have a breaker bar and small 5lb hammer and it won't budge.
A trick I've heard about, but never tried, is to use the starter to break that bolt loose.
I have used a five foot pipe on a breaker bar to get one off. Luckily it didn't twist the bolt off in the crank. Those bolts must be pretty strong.
Thanks so much, my braker bar was just long enough to reach the frame on the rt side. I touched the starter a couple times, had to reset the bar each time, and the bolt came loose!!
