Sponsored by: Real Truck
EBP sensor code
Old Oct 3, 2012 | 06:20 PM
bubblechaser's Avatar
bubblechaser
EBP sensor code
i have a 2006 f250 4x4 6.0 and i would like to know how to cear codes. i have a ebp code and i think its fixed but i dont know how to clear the stored code
Old Oct 3, 2012 | 07:01 PM
sprocket226's Avatar
sprocket226
Thinking your sub-forum choice to ask this question is kinda off...
Old Oct 3, 2012 | 09:08 PM
Yahiko's Avatar
Yahiko
Go here >>>>>> 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You will get more help with the 6.0L
Maybe the Moderator will move this for you
The easy way is with a code reader. You should get a
ScanGaugeII : Linear Logic - Home of the ScanGauge
they have them at Autozone also and then program in the Xguages
and you will have a lot of the needed info for this motor and
also be able to clear most codes. It's a very useful tool for out motors.
I say most because I found that there are some it won't clear
and had to use my Snap-on MT2500 to clear them. But I use the
ScanguageII with the Xguages to keep an eye on things day to day
If you need help with this just ask in the 6.0L Power Stroke Diesel Forum
and someone will help.
The only other way to clear codes is un hook the batteries and turn the
headlight switch to on for 15 minutes. The down side to that is it also
clears all the learned driving data and you will have to re-teach your
truck how you drive. That can take some time.
Sean
Old Oct 6, 2012 | 01:48 PM
bubblechaser
thanks for the info. i am new to this and relized i did it wrong after i sent it. thanks again
fdaugher
Nov 27, 2010 07:02 PM
makomarine
19
Feb 18, 2008 10:40 PM
toolboxjunky
Computer Chips & Tuners
Jan 9, 2007 11:56 AM
2kstroker
Nov 16, 2005 02:53 PM
paul812
Garage & Workshop
Nov 23, 2004 03:10 PM
