General Diesel Discussion
12 v oil pump for adding a filter?
Old Nov 7, 2012 | 01:27 PM
parkland's Avatar
parkland
Originally Posted by nitrogen
We run single cylinder diesel gensets 3500 watts. We run them all night most days in winter. We change the oil at Christmas time and again spring. They just won't die. They are at least four years old and more likely 7 years old. All we is change the oil and let them run
What you need so much power for?
Old Nov 7, 2012 | 01:43 PM
nitrogen's Avatar
nitrogen
Each unit has a C7 cat as well as a C18 cat. Block and pan heaters on both plus a heater blanket on a 50 gallon hydraulic oil reservoir
Old Nov 11, 2012 | 09:00 AM
pennswoodsed's Avatar
pennswoodsed
12 v oil pump
Look in the road racing parts web sites ,they use 12 volt pumps to circulate rear and trans lube .
Old Nov 11, 2012 | 10:19 AM
nitrogen's Avatar
nitrogen
The problem with "racing" parts is that generally they are designed to maximize performance over long life. They are also prepared to do major repairs and replacements after every race.
Old Nov 11, 2012 | 10:37 PM
parkland's Avatar
parkland
I think the best Idea so far is a hydraulic pump....
Should outlast the engine pumping at almost zero pressure.
SkySkiJason
62
Dec 18, 2012 07:43 PM
92P72CrownVic
May 9, 2008 07:32 AM
ranger7570
Oct 24, 2007 01:30 PM
Rons98
3.8 & 4.2L V6
Mar 28, 2005 06:05 PM
LedheadELH
Dec 3, 2004 06:06 PM
