Coolant Filter
Old Oct 4, 2012 | 12:10 PM
Cell's's Avatar
Cell's
Thank-you for the part #'s . I have been thinking for awhile about putting in a coolant filter .
Old Oct 4, 2012 | 12:14 PM
Supercab's Avatar
Supercab
Wink
Originally Posted by timmyboy76
Kel, nows a good time as well, if not acquired yet, but to install the "wrap around" top radiator hose.
I swapped to the "wrap around" hose just before I installed the DieselSite coolant filter setup on mine....The hose rubs aganst the filter cartridge itself enough that I really didn't like it, so I went back to the other hose and have about an 1/8" clearance....
Old Oct 4, 2012 | 12:48 PM
honeydew's Avatar
honeydew
Mine does this too and I don't care for it either. It's been on there for a couple years and doesn't seem to have worn into the hose at all.
Those installing their own should be aware of this and make sure to account for the tight fit with the round-the-belt hose.
Old Oct 4, 2012 | 01:26 PM
KelVarnson's Avatar
KelVarnson
I'm making my own bracket, and I am offsetting the filter toward the passenger side slightly to account for this.
Old Oct 4, 2012 | 01:58 PM
honeydew's Avatar
honeydew
Here is how mine contacts the canister and valve
Old Oct 4, 2012 | 02:12 PM
grec-o-face's Avatar
grec-o-face
Here's my DIY... You can see where the filter contacts my 'round the belt hose.
Old Oct 4, 2012 | 02:13 PM
KelVarnson's Avatar
KelVarnson
Travis, looks like you could fix that with a right-angle fitting (or even a 45) pointed backwards.
Old Oct 4, 2012 | 02:18 PM
honeydew's Avatar
honeydew
Good idea I'll look into that, thanks.
Edit: Looking at Greg's pics got me thinking- there is also a port on the top of my housing (not visible in pic). Maybe I'll use a 90 and move the return to there.
Old Oct 4, 2012 | 02:43 PM
Pitcrw6's Avatar
Pitcrw6
Mine is also contacting the around the belt hose so I glued a piece of teflon too the hose with contact cement.
Old Oct 4, 2012 | 02:49 PM
grec-o-face
Edit: Looking at Grec's pics got me thinking- there is also a port on the top of my housing (not visible in pic). Maybe I'll use a 90 and move the return to there.
I attempted to put a 90 on the top, but it looked really crappy. Just looked like a mess of plumbing pipes & fittings hodge-podged together. If I could have found a decent looking 90 (like an Earls fitting, or something similar) I would've used it.
Also, I didn't want to pay for a valve, so I just pinch the hose with some pinch off pliers when I'm changing the filter.
Old Oct 4, 2012 | 02:57 PM
KelVarnson's Avatar
KelVarnson
So the port on the top of the billet housing is on the return side of the filter element?
Old Oct 4, 2012 | 03:03 PM
grec-o-face
I don't know much about the billet housings. Can you see inside the housing to determine flow paths? I'd think there'd be some markings on it somewhere otherwise.
I'm using the same (carquest) housing as Guzzle. My "side" port is the inlet, and top port is outlet (return).
Old Oct 4, 2012 | 03:28 PM
  #28
timmyboy76's Avatar
timmyboy76
damn grec, were rock'n the same "T"..lol. I put the 90* atop the base so the hose wouldnt be so high.
Old Oct 4, 2012 | 03:43 PM
  #29
grec-o-face
I got the idea of using the "pex" T from someone's thread. Maybe it was yours...??? Hahaha
  #30
honeydew's Avatar
honeydew
I don't know for sure but will definitely confirm that. It is offset so might in fact be on the inlet side.
