Steering pump whine
Old Nov 10, 2006 | 02:03 PM
rickdb1's Avatar
rickdb1
Steering pump whine
I have a 1995 F-150 with the 5.0. In the last 4 or 5 years, I have replaced the power steering pump several times because of the whining noise it puts out. Was this a problem with these trucks or is mine just plagued? I see alot of other older 150's and I don't hear them making this noise. This happens whether I'm turning or going straight. You can really hear it any time when you accelerate. Any solution to the problem that I'm missing?
Thanks,
Old Nov 10, 2006 | 02:15 PM
quicklook2's Avatar
quicklook2
they all make some noise, some more than others.
i completly drained mine, needed new hoses and filled it up with 100% lucas power steering fluid.
it was expensive stuff and quited mine down to almost no sound at all.
Old Nov 10, 2006 | 02:16 PM
Conanski's Avatar
Conanski
Keep the fluid topped up.
Seiously, I have never replaced a pump, and the only time it made the classic Ford power steering whine was when it was low on fluid.
Old Nov 10, 2006 | 03:00 PM
rickdb1's Avatar
rickdb1
Thanks Guys. The fluid level is good. I'll try the Lucas fluid and see if that helps. It really gets annoying sometimes when the pump is louder than the engine noise....
Old Nov 10, 2006 | 04:42 PM
lostin90s's Avatar
lostin90s
Every truck we have at work wines 15 of them, no matter what I do run lucas in the 2 I run but still have the wine. But the better the fluid the quiter they are. Good luck
__________________________________
94 F150 XLT 4x4 SC LB Masf 302 E4od
Old Nov 10, 2006 | 06:26 PM
Old Rust Bucket's Avatar
Old Rust Bucket
Yeah mine does the same. Realy squeals if you turn too sharp. has a tendency to wake a person up from a half asleep state of mind
Old Nov 10, 2006 | 11:41 PM
-Mike-'s Avatar
-Mike-
If you want to fix it permanantly stop using the Ford pump and swap in a GM Saginaw pump.
Not olny is it silent, but it has a lot more pressure so it steers so much easier too.
Kragen/Cardone part number 20-6244 is a direct bolt in, and you will also need a pressure hose from a van because of the larger fitting to go with it.
Or go to a junkyard and find an Econoline van of a simmilar year with the same engine and take teh GM powersteering pump, the aluminum pump bracket, and the pressure hose.
I did the swap a few months ago, and it was the best thing I ever did. I wish I did it sooner. It makes it sound like a completly different truck without the whine, and it steers much easier too so if you have big tires at low pressure the steering is effortless
Old Nov 11, 2006 | 09:30 AM
rickdb1's Avatar
rickdb1
Thanks Mike. Sounds like a plan.
Old Nov 11, 2006 | 10:19 AM
alabamabuddog's Avatar
alabamabuddog
Mine has done it since I bought it. I have had it for 12 years. Its a 92.
Old Nov 12, 2006 | 04:35 AM
metmag52's Avatar
metmag52
Mine whines so bad I have to shut the truck off at Dunkin Donuts drive-thru---
I have had 4 f-150's and all have whined some--Think I will try the new fluid !!!
Gary
Old Nov 12, 2006 | 07:29 AM
rickdb1's Avatar
rickdb1
Good to know I'm not alone....
Old Nov 12, 2006 | 08:46 AM
sbowling79's Avatar
sbowling79
I have had three Ford trucks an 85 F150 A 91 F150 and my current 96 F250 and none of them have wined. Are you guys using tranny fluid in your pumps? I always use clear power steering fluid and have never had a problem
Old Nov 12, 2006 | 08:50 AM
rickdb1's Avatar
rickdb1
Yep. Always use power steer fluid. Must be the pumps I'm buying. Got them at Autozone....
Old Nov 12, 2006 | 06:57 PM
sbowling79's Avatar
sbowling79
I have never had much luck with parts from places like that except Napa it seems like there stuff is usually better or you can really spend some money and go to your Ford dealer.
Old Nov 12, 2006 | 08:59 PM
pepsf250's Avatar
pepsf250
I had that happend to my 1994 f150 4.9L 5sp about in the year 2000, I drained and flushed the old fluid and filled it with new tranny fluid and to this date it has not winned anymore. I would never put anything from GM in my fords! Good luck!
2003 f250 SD CC 5.4L SB
1977 f250 custom 351M/400 V8
