Trans mount
Old Oct 2, 2012 | 09:52 PM
davewave649's Avatar
davewave649
Trans mount
I'm pretty sure the rubber bushing/insulator in between my trans and crossmember is shot. The trans is a C4 and I don't know what vehicle it came out of. How do I figure out what insulator to replace it with? I will take and post pictures tomorrow to help
Old Oct 3, 2012 | 04:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4 has 11 trans pan bolt holes. The original A/T is the FX Cruise-O-Matic, trans pan has 14 bolt holes.
What size is the engine? C4's were not factory installed with 223/292's.
The original crossmember bolted to the frame rails, when some peeps swapped in C4's, they used the bolt-to-the-frame rails rear engine support from a truck that came w/a C4.
C4: 1965/79 F100/250 240/300 I-6 / 1969/79 F100 302 / 1975/79 F150 302 / 1973/77 Bronco / Misc 1964/82 Ford/Merc Passenger Cars.
Trans ID tag was originally located on the round servo cover, left (drivers) side of the case. Most of these tags are missing today.
If the steel/rubber insulator (is it rectangular?) is genuine Ford, it will have ID engineering numbers molded into the rubber.
Old Oct 3, 2012 | 12:23 PM
davewave649
The motor is a 302 and the trans mount is welded in I believe. I will look for an engineering number as soon as I get a chance. Do you know where on the runner it would be?
Old Oct 3, 2012 | 12:43 PM
NumberDummy
Somewhere on the rubber, don't recall where. Most likely the engine & trans were installed as a unit. Look on the curved section of the dizzy for its stamped ID number, see if there's an ID tag on the carb, post these numbers.
Old Oct 3, 2012 | 12:50 PM
davewave649
I know there is no ID tag on the carb, even if there was it wouldnt be original seeing as its got a 4 bbl holley and was running a 4bbl edelbrock for a while. Ill look at the dizzy friday when Im back in Ventura. I just swapped in an MSD dizzy so the factory one is in a box at home.
Old Oct 3, 2012 | 12:53 PM
NumberDummy
Another place to look for an ID number...on the curved side section of the harmonic balancer.
Old Oct 3, 2012 | 01:22 PM
davewave649
OK i will look and see what i can find. Today is kind of a busy day so i dont know what ill be able to look at
vols_fan22
May 12, 2009 04:22 AM
F.ROCK
Oct 16, 2008 05:49 AM
DannyP
Jul 11, 2006 03:00 AM
murphydo
Feb 8, 2001 08:57 PM
