24 transfer case
Old Sep 27, 2012 | 10:30 AM
wildfoot6's Avatar
wildfoot6
24 transfer case
Does any one know where I can get get parts for a 24 transfercase. I am looking for that speedometer gear which is made out of steel. It's a 20 tooth gear, I think I am missing an o-ring. Its not a tight fit in the housing.
Last edited by wildfoot6; Sep 28, 2012 at 07:56 AM. Reason: correction not a 204, not a 19 tooth gear
Old Sep 27, 2012 | 06:59 PM
1972RedNeck's Avatar
1972RedNeck
Do you have a Dana 24 or a NP 205? 204 could be a misprint for both. I am assuming that you have a 24 with the steel speedo gear. I assume you need the driven gear.
I am doing a lot of assuming.
Old Sep 28, 2012 | 07:54 AM
wildfoot6's Avatar
wildfoot6
My Mistake
I meant to say Dana 24, which I think is owned by spicer. which could be spicer 24 now.
Old Sep 28, 2012 | 03:37 PM
1972RedNeck
Send NumberDummy a PM.
Old Sep 29, 2012 | 02:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
20T DRIVEN speedo gear fits on the end of speedometer cable. The only o-ring is a rubber seal (1A-17298-A) that fits on the cable to prevent gear oil from seeping out.
There's a C-clip (B9TZ-17264-A) that retains the gear to the cable.
01T-17271-C .. 20T Speedometer DRIVEN Gear / Marked: 01T-17271-C / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 3 = 606-787-5293.
FREESE MOTORS in Monticello IA has 3 = 319-465-3541.
ANTIQUE AUTO SUPPLY in Arlington TX has 13 = 817-275-2381.
Old Sep 30, 2012 | 10:35 AM
wildfoot6's Avatar
wildfoot6
gear
You are talking about the gear for the transfer case. Where does the o-ring go. On the speedometer housing.
Old Sep 30, 2012 | 11:29 AM
NumberDummy
Is there gear oil associated with a speedometer housing aka speedometer head that is located in the dash?
O-ring fits on end of speedo cable adjacent to DRIVEN gear and C-clip.
Old Sep 30, 2012 | 05:17 PM
wildfoot6's Avatar
wildfoot6
speedo gear from transfer case
Talking about the transfercase speedo gear. Here is a picture.
Old Oct 1, 2012 | 07:27 AM
NumberDummy
And that's what I'm talking about, all the info for this speedometer DRIVEN gear is in post 5.
Old Oct 4, 2012 | 09:26 AM
wildfoot6's Avatar
wildfoot6
speedo.
Are you also saying that the speedo cable gets its lube from the transfer case? Is there any parts missing from the gear, seals or bushings?
RayJay10
May 9, 2010 09:10 AM
nighthawk285
Apr 21, 2007 11:09 PM
tukes48
Nov 19, 2004 01:38 PM
57_ford
Mar 8, 2003 07:36 PM
