TPS Volts Low????
Old Oct 2, 2012 | 08:28 PM
Redeyeracing's Avatar
Redeyeracing
TPS Volts Low????
So my TPS is acting up. Had a dead pedal the other day along with some other symptoms lately. It is on an early build (2 plug pedal assembly) 00 EX. I ran the TPS test on my Auto Ingenuity software and am running .6 volts at idle and the pedal position is at 12.16%. At full throttle I'm only at 3.63 volts and pedal positon at 72.95. When I ohm it out at the plug I have a full 5 volts at the connection? I would think that 3.63 is low for FT. I have read on here that I should be at 4.5ish at FT? Is it a sign that it my unit is going bad? Have read a million posts and no one really had a definitive answer.
Thanks in advance.
Nate
jcitroiv
Jul 21, 2019 03:42 PM
jstihl
Dec 23, 2017 08:18 PM
20powerstroke02
Dec 8, 2015 07:48 PM
Bertelrud
Jun 7, 2009 02:25 PM
Jacksfirstdiesel
Dec 5, 2007 01:41 PM
