Sponsored by: Real Truck
over heated tailight sockets?
Old Oct 2, 2012 | 07:29 PM
rcbsr7's Avatar
rcbsr7
Question over heated tailight sockets?
I have a 2010 F250 SD 15k miles had a taillight go out when I replaced it it appears the socket is discolored from overheating anyone else seen this.
Old Oct 2, 2012 | 09:38 PM
Yahiko's Avatar
Yahiko
Look at the lamp number and make sure it the right one
for that location. I would also check and see how bright
your lights are. It could be that the brake light is on in
place of the tail lamps.
But then again this all is a guess
Sean
Old Oct 2, 2012 | 11:39 PM
galaxie641's Avatar
galaxie641
Had the right rear in our '08 burn up. Replaced 2 bulbs IIRC then finally sucked it up and bought a whole new socket, which has to be spliced in BTW. Had some radio interference go away with the new socket installed as well.
Old Oct 3, 2012 | 12:06 AM
madsonp's Avatar
madsonp
What's probably causing this is corrosion on the contacts of the socket and the bulb. This can cause resistance in the flow of the electricity which as a result can cause excessive heat to be generated in this area. Try cleaning the contacts, and put some dielectric grease in the socket to protect the contacts from corrosion. Another way to think about it, is if you use too small of wire on a high amp circuit, the wire will build up heat because of the resistance of the wire. This is basically what's taking place when there's corrosion on the contacts.
Old Oct 3, 2012 | 08:03 AM
Rongold's Avatar
Rongold
DISCOLORED SOCKETS
All late model vehicles that use the "push in" style of bulbs get the discolored sockets. I get brand new cars in my shop with discolored sockets, but I have never yet seen a melted one. I guess it's cheap plastic.
RON
snake8myelbo
Electrical Systems/Wiring
Jan 20, 2015 03:54 PM
d5332
Dec 21, 2010 02:09 PM
hp246
Jun 11, 2009 05:45 AM
willydad
Feb 24, 2007 02:14 PM
ranger714
Dec 8, 2004 07:32 AM
