More Electrical troubles.
Old Jun 10, 2009 | 08:12 PM
hp246's Avatar
hp246
I have a 76. I know, wrong forum.. Hold on just a second. I have a set of 66 Shield shaped tail lights on my 76 Flare side. Re-wired the entire truck using a American Auto wire kit.
Started out the left tail light worked, but not the right. Figured it was a ground problem. Put a new socket in the right side. Right side worked found that the left was really dull. Figured ground again. Installed new socket in the left side. Now the left side doesn't work at all. I figure it is probably the aftermarket socket. Anyone have an idea where to get a stock replacement socket for these?
The second problem is the dome light. Ford used a 1-wire light. The American Autowire kit is set for a two wire kit. When I tried wiring the Ford lamp, it either stays on all the time or blows a fuse. When I try to wire a two wire lamp, I get nothing. The American Auto WIre kit uses a ground off the light switch, and a hot that comes off the brake pedal switch. Amy ideas?
Old Jun 11, 2009 | 05:45 AM
jowilker's Avatar
jowilker
hp246, Most American made cars are negative chassis ground, meaning a hot fused wire is used to operate something that is grounded to the body that is grounded to the chassis that the negative battery cable picks up to make the complete circuit.
A hot signal from the brake switch, goes to the rear of the truck, lights the bulb that is in a grounded socket.
My first thought is you are not installing it correctly or are doing something that is defeating the system.
I don't know anything about American Autowire but it doesn't look like a replacement system for Ford trucks.
Test the hot wire with a unit that has a bulb in it. Mine looks like a ice pick with a bulb in the handle and a wire coming out of the end that has an alligator clip at the end that I picked up at a parts house.
When the bulb lights, things are working. You continue looking downstream, not upstream.
Hope I didn't cause confusion.
John
Idaho Highboy
Feb 1, 2017 07:26 PM
Colo76F150SC
Aug 2, 2015 05:08 PM
Maxium4x4
Mar 29, 2014 05:47 AM
Stormcloud
Aug 15, 2011 02:55 PM
fmc400
Electrical Systems/Wiring
Jan 17, 2007 04:40 PM
