What do I do now?
Old Oct 2, 2012 | 05:11 PM
yankesfn2's Avatar
yankesfn2
What do I do now?
Truck is throwing a p0269 code. #3 cylinder.
Egr cooler was replaced.
FICM was rebuilt.
Turbo was cleaned.
So do I replace the fuel injector? Please help!
Old Oct 2, 2012 | 05:30 PM
BLADE35's Avatar
BLADE35
I would test the harness before I went after the injector itself
Old Oct 2, 2012 | 07:51 PM
yankesfn2's Avatar
yankesfn2
How do you test the harness?
Old Oct 2, 2012 | 08:30 PM
BLADE35's Avatar
BLADE35
DVM=Digital Volt Meter
Your going to Backprobe Both ends FICM Wire Harness
Google Continuity
(Basicaly is the wire a continous 1 peice NO BREAKS)
Most DVM have a Continuity test setting really easy it Beep Good No Beep NO GOOD
or you can OHM but thats more confussing
and it also needs to carrey a Load
Old Oct 2, 2012 | 08:35 PM
BLADE35's Avatar
BLADE35
Have you made shure all 3 plugs went in and Clicked in???????
If the ficm is Good
then you have 2 Options a Bad Wire harness or Bad Inject
we talking about a 04?????
Old Oct 3, 2012 | 01:56 PM
yankesfn2's Avatar
yankesfn2
FICM was rebuilt last week.
I made sure I heard 2 clicks for each connector.
It's an 2004.
Old Oct 8, 2012 | 05:33 PM
yankesfn2's Avatar
yankesfn2
Has anyone ever cleaned an injector. If so how do you do it?
Old Oct 8, 2012 | 05:46 PM
cheezit's Avatar
cheezit
you really dont clean a nozzle. they put out 25,000 psi of fuel presure. if you plug it, you wont unplug it.
Old Oct 8, 2012 | 06:19 PM
yankesfn2's Avatar
yankesfn2
Thanks Cheezit, you've seen this post, what do you think is my problem is?
Old Oct 8, 2012 | 07:00 PM
cheezit's Avatar
cheezit
injector, harness or ficm. time to do some diag. my vote is injector though
PSDNovice
Nov 6, 2015 08:57 AM
IHdieselfan
Aug 19, 2014 07:43 PM
yankesfn2
Oct 15, 2012 05:49 PM
wulfman
Nov 25, 2010 11:16 PM
Dukhunt22
Apr 25, 2006 03:28 PM
